Tomato, Salt Water & Olive Oil - Buoyancy
In summary, the statement "More of the tomato will be above the surface of the water" is true. Before pouring olive oil, 6.9% of the tomato floats above the surface of the water. After pouring in enough olive oil to completely cover the tomato, you can use the same approach as in #2 to calculate the percentage of the tomato that floats above the surface of the water.
mparsons06
61
1. You put a tomato into a vessel of salty water - it floats. Now you pour olive oil into the same vessel. Which one of the following statements is true?
a. More of the tomato will be above the surface of the water.
b. The tomato will stay at the same height.
c. Less of the tomato will be above the surface of the water.
2. The salty water has a density of 1020 kg/m3 and the tomato a density of 950 kg/m3. Before you pour in the olive oil, what percentage of the tomato floats above the surface of the water?3. After you pour in enough olive oil (density of 870 kg/m3) so that the top of the tomato is completely covered, what percentage of the tomato floats above the surface of the water?
2. The attempt at a solution
1. Correct answer is (a).
2. Correct answer is 6.9%.
ρ of tomato / ρ of salt water
950 kg/m3 / 1020 kg/m3
= 0.931
= 93.1%
100% - 93.1% = 6.9%
3. Not sure how to do it. Do I do the same thing for this as in #2? Please help?
For the third question, you can use the same approach as in #2. The only difference is that now you have to take into account the density of the olive oil as well.
So, the new density of the tomato and olive oil mixture will be:
ρ mixture = (volume of tomato x density of tomato) + (volume of olive oil x density of olive oil) / total volume
= [(Vt x ρt) + (Vo x ρo)] / (Vt + Vo)
Where:
Vt = volume of the tomato
Vo = volume of the olive oil
ρt = density of the tomato
ρo = density of the olive oil
Now, you can substitute the values given in the question and calculate the new density of the mixture. Then, you can use the same formula as in #2 to calculate the percentage of the tomato that floats above the surface of the water.
Related to Tomato, Salt Water & Olive Oil - Buoyancy
What is the concept of buoyancy and how does it relate to tomatoes, salt water, and olive oil?
Buoyancy is the upward force that a fluid exerts on an object that is submerged in it. This force is equal to the weight of the fluid that the object displaces. In the case of tomatoes, salt water, and olive oil, the buoyancy force is influenced by the density of each substance. Tomatoes are less dense than salt water, which is less dense than olive oil. Therefore, the tomato will experience a buoyancy force upward when submerged in salt water, but will sink when submerged in olive oil.
Why does the density of a substance affect its buoyancy?
Density is a measure of how much mass is contained in a given volume. The more mass a substance has in a specific volume, the more dense it is. In the case of buoyancy, the density of a substance affects its ability to displace the fluid it is submerged in. An object with a higher density than the fluid will sink, while an object with a lower density will float.
How do you calculate the buoyancy force on an object?
The buoyancy force can be calculated using Archimedes' principle, which states that the buoyancy force is equal to the weight of the fluid that the object displaces. This can be calculated by multiplying the density of the fluid by the volume of the submerged portion of the object and the acceleration due to gravity.
What is the difference between positive and negative buoyancy?
Positive buoyancy occurs when an object is less dense than the fluid it is submerged in, causing it to float. Negative buoyancy occurs when an object is more dense than the fluid it is submerged in, causing it to sink. In the case of tomatoes, salt water, and olive oil, the tomato experiences positive buoyancy in salt water, but negative buoyancy in olive oil.
How does the buoyancy of tomatoes, salt water, and olive oil impact their use in cooking or food preparation?
The differences in buoyancy between these substances can be used in various ways in cooking and food preparation. For example, when making a vinaigrette dressing, the oil will float on top of the vinegar, allowing for easy mixing. In baking, the buoyancy of ingredients can affect the texture and density of the final product. For instance, adding more oil to a cake batter can make it more dense and moist.
16K
19K
