Top quark heavier than the Higgs?
In summary, the top quark was discovered first because it is produced more frequently and has a more distinct signature compared to the Higgs boson. While the Higgs is produced less often, its decays have a larger background from other processes, making it more challenging to detect. Additionally, there were no viable theoretical alternatives to the top, making it a clear and undisputed target for physicists to search for.
bsaucer
30
If the top quark is heavier than the Higgs boson, then why was it discovered first? Does the top quark get all of its mass from the Higgs? Or does some of its mass come from somewhere else, perhaps a heavier Higgs boson, not yet discovered?
Because mass is not all that determines how difficult it is to discover a particle. (Neutrinos were discovered long after electrons and protons ...)
It is impossible to answer this question. All observations made so far are compatible with the Higgs being solely responsible for the top mass.
The top can be produced via the strong interaction, which means is produced frequently. Usually it is produced in pairs decaying to unusual final states, which makes identification quite easy. Compare this to the Higgs which is produced less frequent, as single particle, and where most decays are indistinguishable from other processes (more details here).
Likes stoomart
Given the precision of electromagnetic instrumentation, it is often easier to detect charged particles than non-charged particles.
Also, perhaps more importantly, most Higgs boson decays have large SM backgrounds from other processes that look similar to Higgs decays. In contrast, a top decay is more distinctive with fewer similar processes to create background. The diphoton decay of the Higgs was critical to its discovery, even though it isn't a particularly large branching fraction of Higgs decays, because it has a much smaller SM background than the more common Higgs decays.
And, unlike the Higgs for which theoretical alternatives were being discussed right up to a few months before it was discovered, there was no viable theoretical alternative to the top. Once a third generation fermion was found, the exact properties of the top, except mass and CKM matrix entries, were overwhelmingly clear and the mass and CKM matrix could be guessed within boundaries from existing data. We knew that the CKM matrix entries for top to strange and top to down had to be vanishingly small and we had a lower bound for the top mass. So there was a pretty clear and more importantly undisputed among physicists, target to search for. A clear target makes it easier to design narrowly tailored searches for what you are looking for in a more efficient way.
This applies only to particles crossing the detector. Both the Higgs and the top decay way too fast for that.
FAQ: Top quark heavier than the Higgs?
What is the Higgs boson and the top quark?
The Higgs boson is a subatomic particle that is responsible for giving other particles their mass. The top quark is another subatomic particle that is the heaviest of all known elementary particles.
Why is the top quark heavier than the Higgs?
The top quark is heavier than the Higgs boson because it has a larger coupling to the Higgs field. This means that it interacts more strongly with the Higgs field and therefore acquires more mass.
How was the mass of the top quark determined?
The mass of the top quark was determined through experiments at the Large Hadron Collider (LHC) in Geneva, Switzerland. By analyzing the energy and momentum of particles produced in collisions, scientists were able to measure the mass of the top quark.
What is the significance of the top quark being heavier than the Higgs?
This discovery confirms the predictions of the Standard Model of particle physics, which is the most widely accepted theory that describes the fundamental particles and forces in the universe. It also sheds light on the mechanism of mass generation in the universe.
Could there be particles that are even heavier than the top quark?
It is possible that there are particles that are heavier than the top quark, but they have not yet been discovered. Further research and experiments are needed to explore the full range of particle masses and interactions.
