A Topology - Boundary of a ball without a point
physics1000
TL;DR Summary
Let us say we have f analytic in Ball_1(0).
which means, radius 1, starting at z_0 = 0 point.
If I want to find the boundary of Ball_1(0).
Will the boundary be {0} or {empty}?
Not homework, just an intuition to understand f(z)=1/z function ( for example ) better.
Let us say we have f analytic in ##Ball_1(0)##. which means, radius 1, starting at ##z_0 = 0## point. If I want to find the boundary of ##Ball_1(0)##. Will the boundary be ##{0}## or ##{\emptyset}##? Not homework, just an intuition to understand ##f(z)=\frac 1 z## function ( for example ) better.
As stated, assuming real space of n dimensions, the boundary consists of all points at a distance 1 from the origin. Your statement is confusing? What has f to do with the ball boundary?
Hi, it does not matter anymore.
Asked someone from my course which I trust and he said to me the answer :)
Basically, As I said.
At complex analysis.
If you have the Ball I said, with radius 1 and it beginning at point zero.
If you create the set of that ball without the point zero, then the boundary will be the unision of ##|z|=1## and ##|z|=0##
Thanks though
I suspect that "someone which you trust" will get the same unsatisfactory mark at an exam as you :)
They're not wrong though, op just phrased it confusingly. Op is asking if you remove the point 0 from the ball, is it now a boundary point? The answer is yes it is.
In a metric space, the boundary of a set S is the set of points at distance 0 from the set.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
