Topology by Simmons Problem 1.2.1
In summary: B}## so for sure that ##x## also belongs to some ##B_i##.No. You are lucky, that you wrote the correct solution directly. You only forgot to motivate some of your steps. You can't just assert, that ##x## is in all of these sets. You have to show it. But you solved the exercise. Great.
Figaro
103
If ##\bf{A}## ##= \{A_i\}## and ##\bf{B}## ##= \{B_j\}## are two classes of sets such that ##\bf{A} \subseteq \bf{B}##, show that ##\cap_j B_j \subseteq \cap_i A_i## and ##\cup_i A_i \subseteq \cup_j B_j##
Since ##\bf{A} \subseteq \bf{B}##, for every ##A_i## such that for all ##x\in A_i## there exist a ##B_j## such that ##x\in B_j##
For ##\cap_j B_j \subseteq \cap_i A_i##,
For every ##x\in \cap_j B_j## and since all ##x## is also in ##A_i##, then ##x\in \cap_i A_i##. Thus ##\cap_j B_j \subseteq \cap_i A_i##
For ##\cup_i A_i \subseteq \cup_j B_j##,
Since ##\bf{A}## ##= \cup_i A_i##, ##\bf{B}## ##= \cup_j B_j##, and from ##\bf{A} \subseteq \bf{B}##. Thus, ##\cup_i A_i \subseteq \cup_j B_j##
Can anyone comment on this proof? I'm not sure about this.
Why are all ##x## in ##A_i##? ##\bf{B}## has more sets than ##\bf{A}##, so there might be elements in some ##B_j## which are not contained in any ##A_i##. What's with them?
##\bf{A} \neq \cup_i A_i ## and ##\bf{B} \neq \cup_j B_j ##
If this were the case, then nothing would have to be shown here.
Hint: Define a function ##\{i\} \rightarrow \{j\}## and consider in the first case a fixed, but arbitrary element ##x## of ##\cap_j B_j## and in the second case a fixed, but arbitrary element ##x## of ## \cup_i A_i##. What does it mean, that these choices belong into these sets?
By the way, do you recognize, that it's a disadvantage not to have named the index sets?
Yes, I made a mistake in your first statement, but why is ##\bf{A} \neq \cup_i A_i ## and ##\bf{B} \neq \cup_j B_j ##
What do you mean by defining a function ##\{i\} \rightarrow \{j\}##? I know that ##i\leq j##. For a fixed but arbitrary ##x## of ##\cap_j B_j##, ##x## should belong to all ##B_j## and in effect it would belong to at least some ##A_i## since for some ##x## in ##A_i## it also belongs to ##B##. Thus ##\cap_j B_j \subseteq \cap_i A_i##.
For the second, for some ##x## in ##\cup_i A_i##, this means that x belongs to at least some ##A_i## but by hypothesis ##\bf{A} \subseteq \bf{B}##, all sets ##A_i## belongs in ##\bf{B}## so for sure that ##x## also belongs to some ##B_i##. Thus ##\cup_i A_i \subseteq \cup_j B_j##
No. ## i \leq j## doesn't make sense and is a direct consequence of ignoring the index sets.
As always, a list of evidences is helpful. We have two sets of sets or classes, but this isn't important here.
##\mathcal{A}=\{A_i\,\vert \,i\in \mathcal{I}\}## and ##\mathcal{B}=\{B_j\,\vert \,j\in \mathcal{J}\}##.
Then we have ##\mathcal{A}\subseteq \mathcal{B}##.
So first of all, where do you get, e.g. ##\mathcal{A}=\bigcup_{i\in \mathcal{I}}A_i## from? ##\mathcal{A}## is a set (class) of sets, not their union.
Now what does this inclusion ##\mathcal{A}\subseteq \mathcal{B}## mean? It means, that every element of ##\mathcal{A}##, that is every set ##A_i## is an element of ##\mathcal{B}##, i.e. a set ##B_j##. But this ##j## depends on ##i##, so we have a function ##\tau \, : \,\mathcal{I} \longrightarrow \mathcal{J}## and an equation ##A_i = B_j=B_{j(i)}=B_{\tau(i)}##.
This is the complete list of given conditions. Nothing specially done so far. I only put more effort in describing the exact situation, as it is always a good habit to start with. It makes everything next simpler and we have a common base to talk, which is by the way the real reason for the points 1 and 2 of our template. It helps to avoid misunderstandings. It is also a good advice for exams. It might look like more time and trouble at the beginning, but it saves more time than it costs during the solution and often helps to avoid mistakes.
No. "At least" doesn't help us, as we want to show, that ##x## belongs to all ##A_i## and not just one.
So let's have this ##x \in \bigcap_{j\in \mathcal{J}} B_j##. Now we know, that some ##B_{\tau(i)}## equal a ##A_i## and some ##B_j## do not. Does it matter, if they don't? Do the ##B_{\tau(i)}=A_i## cover all ##A_i##? Can you go on from here?
I think I get what you are saying, it doesn't matter if some ##B_j## are not equal to some ##A_i## since we are getting the intersection.
Ok, so for all ##x## in ## \cap B_j##, and due to the fact that all ##A_i## are equal to some ##B_j##, all ##A_i## "contribute" to the intersection, but this implies that for every ##x## in ## \cap B_j##, ##x## is also in ##\cap A_i##. Thus ##\cap B_j \subseteq \cap A_i##.
Is my proof for the union correct?
Likes fresh_42
Yes, that's correct, and if you substitute "contribute to" by "are parts of" it's perfect.
You could also say ##\bigcap_{j\in \mathcal{J}}B_j \subseteq \bigcap_{i\in \mathcal{I}}B_{\tau (i)}=\bigcap_{i \in \mathcal{I}}A_i## because the latter intersection is over fewer sets.
FAQ: Topology by Simmons Problem 1.2.1
What is topology?
Topology is a branch of mathematics that studies the properties of geometric figures that remain unchanged when the figure is stretched, twisted, or bent, but not torn or glued together. It is concerned with the study of continuity, connectedness, and convergence.
What is "Topology by Simmons Problem 1.2.1"?
"Topology by Simmons Problem 1.2.1" refers to a specific problem found in the textbook "Introduction to Topology and Modern Analysis" by John Simmons. This problem deals with the concept of continuity and convergence in a topological space.
What is the importance of studying topology?
Topology has many applications in various fields such as physics, engineering, and computer science. It also helps in understanding complex mathematical structures and can be used to solve problems in abstract algebra and geometry.
What is a topological space?
A topological space is a set with a collection of subsets, called open sets, that satisfy certain axioms. These axioms define the properties of continuity, connectedness, and convergence in the space.
What is the difference between topology and geometry?
Topology is concerned with the properties of shapes that remain unchanged through continuous deformations, while geometry deals with the properties of shapes that are unchanged by rigid motions. In other words, topology is concerned with the qualitative properties of shapes, while geometry is concerned with the quantitative properties.
