Topology Words: Reasons for the particular names
  • I
  • Thread starter Cantor080
  • Tags
    Topology
In summary, topology is a branch of mathematics that studies the properties of spaces and the relationships between them. It defines a topology on a set X as a collection of subsets of X that have certain properties, such as being open sets. The openness of a set is crucial in defining other concepts, such as convergence of sequences and continuity of mappings. The term "open set" was first introduced by Dedekind and it is believed to have originated from his description of points and distances as a "body". The use of the term has evolved over time and it is closely related to other concepts in topology, such as inner points, closed sets, and limit points. The origins of the term can be traced back to the late 19th and
Cantor080
From Munkres, Topology: "A topology on a set X is a collection T of subsets of X having the
following properties:
(1) ∅ and X are in T .
(2) The union of the elements of any subcollection of T is in T .
(3) The intersection of the elements of any finite subcollection of T is in T .
A set X for which a topology T has been specified is called a topological space
If X is a topological space with topology T , we say that a subset U of X is an
open set of X if U belongs to the collection T ."
I don't know why the elements of collection T are called as Open Sets here. Nothing seems to be open here to justify its name as there is justification of openness in open interval in real line, for the name to have word open.
[I am thinking to add and ask here, all the other topology related words, with the reason for their particular name (if there is any such reasoning).]
The openness of the set is the basis for all other definitions. What we need from topology is the definitions of convergence of sequences of points and continuity of mappings. Note that the Calculus I definition of continuity is that the value exists and that for every open neighborhood of the value (open interval of radius epsilon) there is a (small enough) open neighborhood (open interval of radius delta) of the point in the domain so that function maps every point in this domain set to the interior of the arbitrary open neighborhood of the value.
No matter how weird and wacky your topological space, you can define limits and continuity of mappings provided you know what the open sets are. The definition of "what are the open sets" defines the topology, it essentially IS the topology. Hence a topological space is a point set for which you know the open subsets. So "open set" then becomes an undefined term in the mathematics of topology along with "set" and "element" and the base generating notation. All the defined terms are defined in terms of these.
Sometimes but not always those open sets are defined via a metric.
The reason for going directly to the open sets is to be as general as possible, e.g. not relying on there existing a specific metric structure to tell you path lengths and thus distances between points.
Likes Cantor080
Dedekind (1871) was the first who defined open sets. He described it with points and distances and called it Körper. The closest translation is probably body. As Dedekind and Cantor essentially built the dream team who started to develop both fields, set theory and topology, I assume that one of them created the term. At least their correspondence and publications should be the starting point of research, possibly Poincaré as well.
Btw., Dedekind's description might well be the reason to call it open, because: "if for any point there is a length such that all points closer than this belong to the system of points, too" settles a kind of open process. Closely related are the terms inner points, closed set, and limit points (innere Punkte, abgeschlossene Menge, Häufungspunkte) and I think one cannot answer the question for one of them without regarding the others. Topology (Listing, 1836 in a letter) had originally be named analysis situs (Leibniz). Hilbert already used the word topology in his famous discourse 1900 without feeling the necessity to explain it.
That's all I have found. So the answer to your question lies probably somewhere between 1870 and 1900, maybe 1920, and Dedekind seem's the right place to start searching.
Likes dextercioby and Cantor080
Related to Topology Words: Reasons for the particular names
What is topology?
Topology is a branch of mathematics that studies the properties of shapes and spaces that are preserved under continuous deformations, such as stretching, twisting, and bending.
How are topology words named?
Topology words are often named after the mathematicians or scientists who first discovered or studied them, or after the objects or phenomena they represent.
What is the significance of the names of topology words?
The names of topology words often provide insight into the properties or characteristics of the objects or phenomena they represent, making them easier to understand and remember.
Can the same word have different meanings in different branches of topology?
Yes, some words may have different meanings in different branches of topology, such as "open" and "closed" which have different definitions in point-set topology and algebraic topology.
Are there any common patterns in the naming of topology words?
Yes, some common patterns in the naming of topology words include using prefixes such as "co-" or "contra-" to indicate the opposite or dual concept, and using suffixes such as "-ology" or "-metry" to indicate the study or measurement of a particular concept.
  • Topology and Analysis
