Torque Converted to Electricity
In summary, the conversation revolves around converting energy to electricity using a piston and cogwheel mechanism. The force pushing the piston is 27,100 tons and the energy in one trip is calculated to be 7.28 * 10^8 J. However, due to losses in generating energy and friction in the cogwheels, the maximum power output is estimated to be 33.7 Kw. The use of the terms "work" and "force" are corrected and the possibility of increasing the output by gearing the generator is discussed.
ronandkryn
Attention FORUM ADMINISTRATOR
Request regarding my thread "Energy Converted to Electricity"
I seem to have asked the wrong question; and would like to restate my problem in different format but still seeking a conclusion that I can use.
A piston moves horizontally [at a constant speed] for
a distance of 9 feet every six hours. Then it immediately reverses its course and moves in the opposite direction at the same speed for the same distance and time. It repeats this travel every day, without interruption. Every day [24 hours] it makes four trips, each trip covering a distance of nine feet. At all times the WORK [energy] pushing the piston is 27,100 Tons.
A metal strip is attached to the side of piston. The metal strip is exposed and lies horizontally from the top end of the piston to the bottom end of the piston; and is exactly equal in length to the piston. Thus, the metal strip rides piggyback [on the side] along with the piston on all of its travels. The exposed side [lateral side] of the piston contains cogs; with the cog teeth protruding toward and interacting with a cogwheel.
The initial cogwheel is very large in diameter, but is then geared down to smaller cog wheels until the final wheel is spinning at a high rate of speed and turning the axel of an electrical generator.
Is it possible to make even a wild guess as to how much electricity could be manufactured from such a contraption?
I suppose you mean: the force pushing the piston is the same as a weight of 27100 tons.
The energy in one trip of the piston = force * distance traveled = 27100*1000*9.81 N * 2.74m = 7.28 * 10^8 J The power required = energy / time = 7.28 * 10^8 J / 21600 seconds = 33703 Watt = 33.7 Kw.
That is the maximum power. Losses when generating energy will be 10-20 % and there are also the losses from friction in the cogwheels.
This would make an incredibly expensive generator, since it has to deal with such large forces, and delivers only as much power as a small car engine.
Please start forcing yourself to use the right terms. A ton is force, not work or energy (or pressure as you said in your other thread!).
Absolutely! You haven't changed anything relevant to the energy calculation so the calculated energy is the same as it was before! Same force, same distance, same time.
willem2 got a slightly different answer probably due to different conversion factors (I haven't checked the math...). [edit] Found it - willem2, since the distance is given in feet, you should probably assume those are English tons, not metric tons!
You seem to think you can increase the output of a generator by gearing it to spin faster. You can't. As you gear it up, you decrease the torque applied exactly proportionally. This is a form of mechanical advantage: http://en.wikipedia.org/wiki/Mechanical_advantage
Related to Torque Converted to Electricity
1. How is torque converted to electricity?
Torque is converted to electricity through the use of a device called a generator. The generator uses a rotating shaft, driven by a source of torque, to turn an electromagnet inside a wire coil. This movement creates an electrical current that can be used to power devices.
2. What is the relationship between torque and electricity?
The relationship between torque and electricity is that torque is a force that causes rotation, and electricity is a form of energy that can be produced by this rotation. The greater the torque applied, the more electricity can be generated by the generator.
3. Can any type of torque be converted to electricity?
In theory, any type of torque can be converted to electricity as long as there is a way to transfer the rotational motion to a generator. However, the efficiency of the conversion may vary depending on the type of torque and the design of the generator.
4. What are some common sources of torque used to generate electricity?
Some common sources of torque used to generate electricity include wind, water, and steam. Wind turbines use the force of wind to turn the blades and generate electricity. Hydroelectric power plants use the force of water to turn turbines and produce electricity. Steam turbines use the pressure of steam to turn the blades and generate electricity.
5. Are there any limitations to converting torque to electricity?
One limitation to converting torque to electricity is that the efficiency of the process is not 100%. Some energy is lost during the conversion, so the amount of electricity produced may be less than the amount of torque applied. Also, the availability of torque sources, such as wind or water, may be limited in certain areas.
11K
