Torque direction rule and metamaterials
In summary, the direction of torque is determined by convention, but what determines this convention is still unknown.
metalore
Hi, I´m new. I actually found this board with the message about speculative theory about the density of space and its relation to time but I see that post is two years old.
Anyway I have another simple question that I just can´t find the answer to.
What determines the direction of torque!?
Is this just an unexplained phenomenon of the universe? I understand that the torque direction of all natural materials can be determined by using the right-hand rule. However, the left hand rule is also used but only for certain man-made left-handed or negative index materials.
I also understand this is related to "metamaterials" which have a negative refractive index and are not natural but man-made. Are there any natural occurring materials that use the left-hand rule for torque but are not metamaterials (i.e. have a normal refractive index but still use the left-hand rule for torque)?
What is determining this direction, and why do all natural materials use the right hand rule?
Refractive index has nothing to do with torque. Can you give an example of a material that uses the left-hand rule for calculating torque?
Really, you can use the left-hand rule instead of the right-hand rule if you want, as long as you are consistent, and as long as you distinguish between polar vectors (ordinary vectors) and axial vectors (vectors that are calculated from the cross product of two polar vectors).
Right-hand vs. left-hand is merely a sign convention. We could also, for example, choose all of our velocities to be negative. It wouldn't affect the physical results (but it might be more cumbersome to calculate with).
Also, left-handed torque would be used in left-handed coordinate systems (which could be what you're referring to). But this has no bearing on the actual physics; it's just a bookkeeping device.
Okay, I haven´t really read about anything that uses the left hand rule for torque. But I have read about materials that use the left hand rule for opposite wave propagation and a negative refractive index (are those two related)?
I wonder if these are really torque-like properties being expressed on a microscopic level? In any case, my original question still stands: Why do naturally occurring materials use the right-hand rule and not the left (Whether it be torque, wave propagation, or refractive index)? What determines this direction? All I read is that using the right hand is a "convention", but it does not explain why everything goes in that direction in the first place. The fact that materials which use the left-hand rule are "unique", begs the question what is determining this direction in the first place?
I do know that artificially creatd metamaterials are able to produce the negative refractive index because of man-made changes in the structure of the material (as opposed to composition). But what was in the composition of all natural materials in the first place that makes them all use the right-hand rule.
Admittedly I should have titled this thread "Right-hand rule vs left-hand rule" since this is not just about torque.
FAQ: Torque direction rule and metamaterials
What is the Torque Direction Rule?
The Torque Direction Rule is a principle in physics that states that when an object is in rotational equilibrium, the sum of the torques acting on the object must be equal to zero.
How is the Torque Direction Rule applied in metamaterials?
In metamaterials, the Torque Direction Rule is used to design structures that can effectively manipulate electromagnetic waves. By controlling the direction of the torques acting on the waves, metamaterials can be used to create devices such as invisibility cloaks and perfect lenses.
What are metamaterials?
Metamaterials are artificially created materials that have unique properties not found in nature. These materials are designed to have specific structures at the nanoscale, allowing them to manipulate electromagnetic waves in ways that traditional materials cannot.
What makes metamaterials important in scientific research?
Metamaterials have the potential to revolutionize many fields of science and technology, including optics, telecommunications, and medicine. They have the ability to manipulate electromagnetic waves in ways that were previously thought impossible, opening up new possibilities for innovation and discovery.
What are some real-world applications of metamaterials?
Some potential applications of metamaterials include improved solar cells, enhanced medical imaging techniques, and more efficient wireless communication devices. They may also be used in the development of advanced sensors, high-speed computing, and even cloaking technology.
