Torque for drill to shear through material
In summary, a drill bit that is advanced at a fixed feed rate does two things. It shears the material, then rolls the material into a spiral, (or breaks it into chips), that will pass out through the spiral flutes of the drill. The bottom of the cutting edge has a relief angle sufficient to prevent continued frictional contact with the material not yet displaced. The top of the cutting edge is subjected to frictional, where the swarf is curled. The hard TiC coating on drill bits is really only a benefit on top of the cutting edge for curling the swarf. By using a lower feed rate with a closer pitch, more shearing must be done per unit length of hole, while the swarf is
Galer
I'm attempting to figure out the torque required for a twist drill bit to shear through a material. I have no idea if this is even remotely correct but this is the process I used.
Ultimate shear strength = Force/Area
Therefore Force = USS x Area
The USS of the material = 360 N/mm^2
I assume the only cutting surface on the drill bit is the tip which is approximately a cone shape. So I worked out the surface area of a cone
A = pi*r*(r+(√(h^2+r^2)))
Then subtracted the area of the circular base of the cone because we only care about the pointy bit of the cone. I'm thinking the surface area of the pointy part of the cone would equal the area resisting shear, assuming the drill was already starting in a pre-drilled hole rather than on a flat surface.
Area resisting shear = 91.6 mm^2
Put this into our first formula. F = 360 * 91.6 = 33 KN
This gives me a linear force but the drill is rotating so the force needs to be expressed as torque. And to do that I used
Torque = Force*radius = 33000*0.005 = 165 N.m of torque required to shear through the material.
Where radius is the radius of the drill bit (5mm)
So can this process give me an approximately accurate idea of the torque needed for a drill to cut through something? Or am I way off?
Doesn't look too bad.
This is probably high. The material is not going to be shearing over the entire surface area, but deformation of chips could make up the difference.
A drill bit that is advanced at a fixed feed rate does two things. It shears the material, then rolls the material into a spiral, (or breaks it into chips), that will pass out through the spiral flutes of the drill.
By using a lower feed rate with a closer pitch, more shearing must be done per unit length of hole, while the swarf is easier to roll into a spiral because it is thinner. The fine swarf produced will have less stability and a greater velocity in the drill flutes. By using a greater feed per turn, less shearing is being done while it is significantly harder, (a power law of feed rate), to roll the swarf or break it into chips.
The optimum feed rate will therefore be decided by the balance between the forces needed to shear and to deform the material.
Maximum RPM is decided by the temperature of the cutting edge, the drill material characteristics and the coolant used, (which may also modify friction).
For those reasons, the energy needed to drill a hole must consider shear, deformation and friction.
The torque requirement will be a function of feed rate since deformation of the sheared material plays such an important part. In my opinion, the quick and therefore economic drilling of holes may not need to consider shear if the drill is sharp. The greater proportion of the energy goes into curling the swarf.
Related to Torque for drill to shear through material
1. What is torque and why is it important for a drill to shear through material?
Torque is a measure of the twisting force applied to an object. It is important for a drill to have enough torque to shear through material because it determines the drill's ability to rotate and penetrate the material.
2. How is torque calculated for a drill?
Torque for a drill can be calculated by multiplying the force applied to the drill by the distance from the point of rotation to the point where the force is applied. This is known as the moment arm.
3. What factors affect the torque needed for a drill to shear through material?
The torque needed for a drill to shear through material depends on several factors, including the type and hardness of the material, the size and type of drill bit, and the speed and power of the drill.
4. Can too much torque be harmful for a drill when shearing through material?
Yes, too much torque can be harmful for a drill when shearing through material. It can cause the drill to overheat, wear out more quickly, or even break if the torque exceeds the drill's maximum capacity.
5. How can torque be adjusted for different materials and drilling situations?
Torque can be adjusted for different materials and drilling situations by changing the speed and power settings on the drill, using different types of drill bits, and using lubricants or cooling methods to reduce friction and heat buildup.
  • Mechanical Engineering
17K
16K
  • Mechanics
19K
