Torque formula derivation for a particle moving in circular
The discussion centers on the derivation of torque for a particle moving in a circular path with tangential velocity. It clarifies that dr/dt represents the velocity vector, which encompasses both radial and tangential components, rather than just radial velocity. The position vector r is emphasized as being crucial to understanding the particle's motion. While torque is mentioned, it is noted that it differs from the conventional torque seen in rigid body systems and is defined mathematically as the cross product of the position vector and the net force. The conversation highlights the importance of distinguishing between different types of torque in various contexts.
Father_Ing
L = r x p
Consider that the particle is moving in circular with tangential velocity v, and (0,0)is its origin.
I wonder why dr/dt is equal to tangential velocity instead of radial velocity (since dr/dt means how much change in radial distance in a really short duration of time)
Note that r is the position vector of the particle, not merely the distance to the particle.
Likes Father_Ing and Delta2
Yes usually the bold letters in equations represent vectors. So ##\mathbf{r}## is a vector (the vector that denotes the position of the particle, hence position vector) and ##\frac{d\mathbf{r}}{dt}## is the velocity vector (by definition the velocity vector is the first time derivative of the position vector). It is the whole velocity, not only the radial or only the tangential.
There is no torque in this situation.
There is torque but it is not the "usual sense " torque that we have in rigid body systems.
Here the torque is more in the mathematical sense as the cross product of the position vector and the net force that is being applied to the point particle.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
