Torque - Lady on a diving board
In summary: NIn summary, the problem involves a woman weighing 500 N on a diving board with a length of 3.90 m, supported by a fulcrum 1.40 m away. The objective is to find the forces exerted by the bolt and the fulcrum, represented by F1 and F2 respectively. Using the equation for torque, F2 can be calculated and then used to find F1. The final solution is F1 = 500 N and F2 = 1250 N.
tascja
87
A woman whose weight is w = 500 N is poised at the right end of a diving board with a length of Lw = 3.90 . The board has negligible weight and is bolted down at the left end, while being supported L2 = 1.40 m away by a fulcrum, as figure shows. Find Forces F1 and F2 that the
bolt and the fulcrum, respectively, exert on the board.
T= rFsin(theta)
Since there are two unknown forces, can i solve for them separately, assuming the axis of rotation is different in each?
to solve for F1 i would have that the fulcrum in the axis of rotation, assuming F2 is 0 for acting on the axis of rotation. and for F2 i would have the fulcrum at the bolt...
  • physics.doc
You can calculate momentuma around bolt.
ΣM=0 F2*1,4 - w*3.9=0
F2=w*3.9/1,4
After you get F2, you can easily calculate F1:F1=F2 - w
I would approach this problem by first defining the variables and equations that are relevant to the situation. Torque, as given by the equation T = rFsin(theta), is a measure of the force that causes an object to rotate around an axis. In this case, the axis of rotation is at the fulcrum where the diving board is supported.
To solve for the unknown forces, F1 and F2, we can use the principle of torque equilibrium, which states that the total torque on an object must be equal to zero for the object to be in rotational equilibrium. This means that the sum of the torques acting in the clockwise direction must be equal to the sum of the torques acting in the counterclockwise direction.
In this scenario, we can consider the forces acting on the diving board at two different points - the bolt and the fulcrum. At the bolt, the only force acting is F1, which is the force exerted by the bolt to hold the diving board in place. At the fulcrum, there are two forces acting - F2, the force exerted by the fulcrum to support the diving board, and the weight of the woman, w.
To solve for F1, we can set up the equation for torque equilibrium at the bolt, where the axis of rotation is located. This gives us:
F1*L2 = w*Lw*sin(theta)
Where theta is the angle between the force and the lever arm, which in this case is 90 degrees. This simplifies to:
F1 = w*(Lw/L2)
Substituting in the given values, we get F1 = 500 N * (3.90 m / 1.40 m) = 1428.57 N. This is the force exerted by the bolt to hold the diving board in place.
To solve for F2, we can set up the equation for torque equilibrium at the fulcrum, where the axis of rotation is also located. This gives us:
F2*Lw = w*Lw*sin(theta)
Again, theta is 90 degrees, so this simplifies to:
F2 = w = 500 N
This means that the fulcrum must exert a force of 500 N to balance out the weight of the woman and keep the diving board in equilibrium.
In conclusion, the forces F1 and F2 exerted by the bolt and the fulcr
Related to Torque - Lady on a diving board
What is torque?
Torque is a measure of the twisting force applied to an object. It is calculated by multiplying the force applied by the distance from the point of rotation.
How is torque related to rotational motion?
Torque is directly related to rotational motion. It causes objects to rotate around an axis, and the magnitude of the torque determines the speed of the rotation.
What factors affect torque?
The two main factors that affect torque are the magnitude of the applied force and the distance from the point of rotation. The longer the distance, the greater the torque.
What is the significance of the "Lady on a diving board" in the concept of torque?
The "Lady on a diving board" is a classic example used to demonstrate the concept of torque. It shows how the distance from the point of rotation can greatly affect the amount of torque, as the further the lady leans out, the greater the torque applied to the diving board.
How is torque measured?
Torque is measured in units of force multiplied by distance, such as newton-meters or pound-feet. It can be measured using a torque wrench or calculated using the formula torque = force x distance.
