Torque of Pulley with Two Masses2
Either way works as long as you keep things straight.In summary, the weights connected by a cord over a frictionless pulley with a radius of 0.300 m and a weight of 40.0 N results in the pulley applying a downward force on the hook due to its own weight and two different tension forces. The equations for the motion of the weights and the torque equation must be set up correctly in order to find the correct values for the tension forces. The signs for acceleration must also be taken into consideration and can be coordinated along the pulley for easier understanding.
BBA Biochemistry
Two weights are connected by a very light flexible cord that passes over a 40.0-N frictionless pulley of radius 0.300 m. Weight #1 is 125 N and Weight #2 is 75 N. The pulley is a solid uniform disk and is supported by a hook connected to the ceiling. What force does the ceiling exert on the hook?
F=ma
τ=FtanR=Iα
[/B]
The pulley applies a downward force to the hook. Since the pulley isn't accelerating, the net force on it must be zero. The pulley's downward force on the hook is due to its own weight, but also two different tension forces since the pulley isn't massless.
First, I decide to try and find the two tension forces, T1 and T2. I set up equations for the motion of the hanging weights:
F1=m1a=T1-m1g
F2=m2a=T2-m2g
Since they are connected by a rope, they should have the same acceleration.
a= [T1-m1g] / m1
I plugged this into the equation for F2, getting:
m2[T1-m1g] / m1 = T2-m2g
There are still two unknowns in this equation, so I set up a torque equation:
τ=FtanR=Ipulleyα
Using the moment of inertia of a solid cylinder (0.5McylR2) and a=αr, The torque force is (assuming no slipping):
(T1-T2) x R = 0.5Mpulleya
I solved this torque equation for T1, getting:
T1=0.5(Mpa+T2
I then plugged this into my F1 equation to solve for acceleration. I then used acceleration to solve for T2. After finding T2, I used its value to solve for T1. The algebra got a bit complex, and I ended up with 3.19 N for T2 and 63.2 N for T1, which are incorrect.
Can anyone point out if my equation set up was incorrect or if I messed up in the algebra?
Not exactly. There is a crucial difference. Hint: acceleration is a vector.
On first glance, you have assumed that the accelerations are the same. This is not true. They have the same magnitude but in opposite directions.
So the acceleration of weight 1 and weight 2 are opposite. That would make my F1 and F2 equations:
F1=m1(-a)=T1-m1g
F2=m2a=T2-m2g
Would the linear acceleration of the rotating pulley also be negative?
Edit: I did the math with the following equations:
F1=m1(-a)=T1-m1g
F2=m2a=T2-m2g
τ=T1-T2=0.5Mp(-a)
(With the pulley's linear acceleration in the negative x-direction)
The algebra was quite involved (I got equations with 5-6 terms on each side and usually an indicator that I did something wrong), but I went through and got T2=-8.33N and T1=-33.7 N. I added these together along with the 40 N weight of the pulley, getting -82.03 N downwards force being applied by the pulley onto the hook, so the hook would apply 82.03 N back, but this was incorrect. Are my three equations incorrect or should I just double check my math?
m1(-a)=T1-m1g
That says you are taking a as positive down on the weight 1 side.
T1-T2=0.5Mp(-a)
If weight 1 goes down then T1>T2, but this equation would make a negative.
T2=-8.33N
Negative tension? That should have been a hint.
I'm still confused on the signs. Weight 1 (125 N) would go down, hence it's acceleration is downward. Hence the negative sign in front of the a term. Weight 2 (75 N) goes up, so its acceleration is positive.
I'm shooting in the dark on the sign of the acceleration for the pulley. For angular acceleration, counterclockwise is positive, but for I'm really not sure on linear acceleration. Can I just use the magnitude of acceleration, since the pulley isn't really translating?
Edit:
Instead of setting up my equations like above, worrying about the sign of acceleration, can I set up my equations like this and have my signs be coordinating along the pulley?
F1=W1-T1=m1a (it will be moving downward W1>T1)
F2= T2-W2=m2a (will move upwards since T2>W2)
I can set up my torque equation to where it's rotating with a positive torque:
T1-T2R=0.5mpR2(a/R)
Which cancels out to:
T1-T2=0.5(Wp/g)a
The directions make more sense to me here. Is this fine?
Edit #2:
These equations turned out to be correct. It took me so long to solve it as I kept messing up the algebra. I ended up having to plug all my numbers into get a much more simple-looking system of equations initially, and then solve them instead of carrying symbols around like we normally do in physics.
Thanks for your help everyone!
T1-T2=0.5(Wp/g)a
Yes.
To be clear, you do not need to guess correctly in advance which way the system will move; you just have to make sure the equations are internally consistent.
If we take a as the downward acceleration for m1, then
m1a = m1g-T1
(T1-T2)r= (moment of inertia of pulley)(a/r)
If we switch to taking a as up for m1 and down for m2 then it is also reversed for the pulley:
m1a=T1-m1g
(T2-T1)r=(moment of inertia of pulley)(a/r)
Likes BBA Biochemistry
FAQ: Torque of Pulley with Two Masses2
1. What is torque?
Torque is a measure of the force that causes an object to rotate around an axis. It is calculated by multiplying the distance from the axis of rotation to the point where the force is applied by the force itself.
2. How is torque related to pulleys with two masses?
In the case of a pulley with two masses, torque refers to the rotational force exerted on the pulley by the weight of the two masses. This torque is responsible for causing the pulley to rotate.
3. How do you calculate the torque of a pulley with two masses?
The torque of a pulley with two masses can be calculated by taking the sum of the products of each mass's weight and its distance from the axis of rotation. This can be represented by the equation T = (m1 x g x r1) + (m2 x g x r2), where T is torque, m1 and m2 are the masses, g is the acceleration due to gravity, and r1 and r2 are the distances from the axis of rotation to each mass.
4. What factors affect the torque of a pulley with two masses?
The torque of a pulley with two masses is affected by the masses themselves, the distance of the masses from the axis of rotation, and the acceleration due to gravity. Additionally, the number and size of pulleys in the system can also impact the torque.
5. How does the torque of a pulley with two masses affect its rotational speed?
The torque of a pulley with two masses is directly proportional to its rotational speed. This means that as the torque increases, so does the rotational speed, and vice versa. This relationship is described by the equation T = I x α, where T is torque, I is the moment of inertia, and α is the angular acceleration.
