tul725
A square clock of inertia m is hung on a nail driven into a wall (Figure 1) . The length of each side of the square is ℓ, the thickness is w, and the top back edge of the clock is a distance d from the wall. Assume that the wall is smooth and that the center of mass of the clock is at the geometric center.
Obtain an expression for the magnitude of the normal force exerted by the wall on the clock. Use the notation l for the length ℓ.
Express your answer in terms of the variables m, l, w, d, and acceleration due to gravity g.
Torque = r⊥*FGravity - Fwall⊥r = 0
I divided the rectangle into 2, lengthwise, and into 2 width-wise. The point at where these lines meet is the center of mass of the clock. I set the point of the nail and the corner of the rectangle as the axis of rotation. I tried to find the lever arm distance of the gravitational force acting on the center of mass of the clock by using trigonometry to find angles. For the normal force of the wall I decided to find the tangential component of the normal force since I already had the lever arm distance in terms of l. I figured since the clock is at rest then the sum of Torque would be equal to zero. The final answer I get is:
https://imgur.com/FGhGKmB
This is not the right answer, and I can't really find where I went wrong.
