Torque required to rotate 5 flywheels connected with 1 belt
In summary, the conversation is discussing the torque required to rotate five flywheels that are connected with one single belt. Each flywheel requires 300 Nm of torque and rotates at 500 rpm. The initial estimate for the total torque is 1500 Nm, but the speaker is unsure and asks for alternatives to minimize the torque. They also question the purpose of using a single belt for all five flywheels if the total torque is 1500 Nm.
vamshi422
Hi,
I have 5 machines with flywheels, which are connected with one single belt, so that all five flywheels rotate together. Torque required for each flywheel to rotate is 300 Nm and rpm is 500.
what would be the total torque required to rotate five flywheels connected with one belt?
Hi vamshi, :welcome:
Without further info I would say 1500 Nm, but you had that already, right ?
Hello BvU, Actually I don't know the total torque. If it is 1500Nm then there is no use of single belt used for all five flywheels.
How could I minimize the total torque to rotate five flywheels and what would be alternatives to minimize the torque?
Well, that isn't much in the department of "further info"...
Would you able to make sense of
what would be the total torque required to rotate five flywheels connected with one belt? ...
if you read it again ?
FAQ: Torque required to rotate 5 flywheels connected with 1 belt
What is torque?
Torque is a measure of the force that causes an object to rotate around an axis. It is typically measured in units of newton-meters (N*m) or foot-pounds (ft-lb).
How is torque calculated?
The torque required to rotate an object is calculated by multiplying the force applied to the object by the distance from the axis of rotation to the point where the force is applied.
What is a flywheel?
A flywheel is a mechanical device that stores rotational energy. It is typically a heavy wheel or disk that is mounted on an axle and used to regulate the speed of a machine.
How does a belt affect torque?
A belt transmits torque from one component to another by creating friction between the belt and the pulley. The amount of torque required to rotate a series of flywheels connected by a belt depends on the friction between the belt and the pulleys, as well as the size and weight of the flywheels.
What factors affect the torque required to rotate multiple flywheels connected with a belt?
The torque required to rotate multiple flywheels connected by a belt is affected by the number and size of the flywheels, the tension of the belt, and the friction between the belt and the pulleys. The weight and distribution of the load on the flywheels can also impact the torque required.
