Torque, Rod Balanced on Fulcrum
In summary: I'm not sure whay you wrote "similarly" here.)I'd prefer not to go any farther because it just gets uglier and its quite time consuming using latex reference. On that note, what the hell do i do to start this problem correctly?In summary, the figure shows two particles, each of mass m, attached to a rigid massless rod of length L1 + L2. When the rod is held horizontally on a fulcrum and released, the particles will experience an initial acceleration. To find the magnitude of this acceleration, we can use the equation τ = (I1 + I2)α, where τ is the net torque on the system, I1 and I2 are the moments
rmunoz
30
The figure below shows particles 1 and 2, each of mass m, attached to the ends of a rigid massless rod of length L1 + L2, with L1 = 17 cm and L2 = 85 cm. The rod is held horizontally on the fulcrum and then released.
(a) What is the magnitude of the initial acceleration of particle 1?
(b) What is the magnitude of the initial acceleration of particle 2?
http://www.webassign.net/halliday8e/pc/halliday8019c10/halliday8019c10-fig-0042.htm
[tex]\tau[/tex]= F(perp)r = ma(tan)*r = m([tex]\alpha[/tex]r)r = (mr[tex]^{2}[/tex])[tex]\alpha[/tex]
[tex]\tau[/tex]=[tex]\tau[/tex]1 + [tex]\tau[/tex]2 ?
F(tan)=mat
[tex]\tau[/tex]= I[tex]\alpha[/tex]
So I have no idea really what I'm doing with this problem but i figured its better to at least try something and fail than to have not tried at all... here is my attempt... its nowhere near right, I allready know that, but can someone at least point me in the right direction?
I'm beyond confused as to where i should even start but perhaps there is some validity in the stuff i put together.
first) Tnet is obviously what we are looking for in order to deduce the acceleration from the known quantities. At the instant the rod begins to turn, the right side is moving downwards and the left is moving upwards, meaning that the torque generated by the force acting on P2 is greater than that of P1.
This is where i go wrong (I'm allmost 99 percent sure i have no idea what I am doing here)
[tex]\tau[/tex]net= r1f1 + r2f2 = I1[tex]\alpha[/tex]1 + I2[tex]\alpha[/tex]2
r1f1 = -9.8m/s[tex]^{2}[/tex]*m*.17m but m is irrelevant because it is the same for both particles therefore
r1f1 = -9.8m/s[tex]^{2}[/tex]*.17m
r2f2 = -9.8m/s[tex]^{2}[/tex]*.85m
similarly, [tex]\tau[/tex]= mr[tex]^{2}[/tex][tex]\alpha[/tex]
OK. (The figure is not viewable, but I think I understand.) Realize that the torques on each mass are opposite (one clockwise, the other counterclockwise) and thus have different signs.
Let's call the torque on m1 positive (counterclockwise), the other negative (clockwise). Realize that there is a single α. So:
τ = r1f1 - r2f2 = (I1 + I2)α
The mass is not irrelevant; keep it.
Recalculate the net torque, taking care with signs. You might want to do it with symbols first, then plug in numbers later on when you solve for alpha. For example: use mgr2 & mgr1 for the magnitudes of the torques.
Find the total I for the system by adding the I for each mass. Yes, I = mr².
I would approach this problem by first identifying the relevant physical principles at play. In this case, we are dealing with torque, which is the rotational equivalent of force, and the rotational motion of a rigid body.
Next, I would draw a free body diagram of the system, showing the forces and torques acting on each particle. Since the rod is held horizontally, we can assume that the fulcrum is not exerting any torque on the system.
Using the equation \tau = I\alpha, where \tau is the net torque, I is the moment of inertia, and \alpha is the angular acceleration, we can set up equations for each particle.
For particle 1, the only force acting on it is the gravitational force, which exerts a torque of \tau_1 = -mg(L_1/2)sin\theta, where \theta is the angle between the force and the lever arm (in this case, the lever arm is L_1/2). We can also write the moment of inertia for particle 1 as I_1 = m(L_1/2)^2, since it is rotating about its center of mass. Setting these equal to each other and solving for \alpha_1, we get \alpha_1 = -2g/L_1 sin\theta.
Similarly, for particle 2, the only force acting on it is the gravitational force, which exerts a torque of \tau_2 = -mg(L_2/2)sin\theta. The moment of inertia for particle 2 can be written as I_2 = m(L_1+L_2/2)^2, since it is rotating about the fulcrum. Setting these equal to each other and solving for \alpha_2, we get \alpha_2 = -2g/(L_1+L_2) sin\theta.
Since the question asks for the magnitude of the initial acceleration, we can take the absolute value of \alpha_1 and \alpha_2 to get the answers:
(a) The magnitude of the initial acceleration of particle 1 is |a_1| = 2g/L_1 sin\theta.
(b) The magnitude of the initial acceleration of particle 2 is |a_2| = 2g/(L_1+L_2) sin\theta.
Note that the answers will depend on the angle \theta, so we
Related to Torque, Rod Balanced on Fulcrum
1. What is torque?
Torque is a measure of the force that can cause an object to rotate around an axis. It is calculated by multiplying the force applied to an object by the distance from the axis of rotation.
2. How is torque related to a rod balanced on a fulcrum?
In the case of a rod balanced on a fulcrum, the torque is balanced on both sides of the fulcrum. This means that the force on one side of the fulcrum is equal to the force on the other side, and the distance from the fulcrum to the point of force application is also equal on both sides.
3. What is the principle of moments?
The principle of moments states that for an object to be in rotational equilibrium, the sum of the clockwise moments must be equal to the sum of the anticlockwise moments. This principle is used to analyze the balance of forces and torques on a rod balanced on a fulcrum.
4. How does the position of the fulcrum affect the balance of a rod?
The position of the fulcrum is crucial in determining the balance of a rod. If the fulcrum is located at the center of mass of the rod, the rod will be perfectly balanced and will not rotate. However, if the fulcrum is moved away from the center of mass, the rod will rotate until it reaches a state of equilibrium, where the torques on either side of the fulcrum are balanced.
5. Can torque be negative?
Yes, torque can be negative. This occurs when the direction of the force and the direction of rotation are opposite. In the case of a rod balanced on a fulcrum, if a force is applied in the opposite direction of the rotation, it will create a negative torque, which can be balanced by an equal positive torque on the other side of the fulcrum.
