Torque to linear force conversion and units
In summary, the conversation discusses the confusion around converting torque to linear force when dealing with threaded rings and rods. The mechanical advantage of the thread is calculated by multiplying the thread diameter by pi and dividing by the thread pitch, which in this case is 56. The question arises about whether to use inch pounds or foot pounds when applying torque and converting it to linear force. The final calculation of 76,776 lbs seems too high, but it is explained that the screw thread acts like a ramp, amplifying the force at the expense of speed. The conversation concludes with the acknowledgement that this type of problem solving is enjoyable.
10mm
I always get my foot-lbs and inch lbs confused and don't know if I am applying the correct unit. If I wanted to know how much linear force I can create from a given amount of torque I apply to a thread, I know that I need to find the mechanical advantage of the thread and the torque applied. I am just wanting to make sure the torque to linear force conversion is correct so I am going to leave out any friction loss etc..
I have a 1.50-12 threaded ring and say the od of this ring is 1.75". First, I find the mechanical advantage of the thread by calculating (1.50 X Pi)/ thread pitch.
1.50 x 3.1416 / .0833=56 mechanical advantage.
Now, here is where I get confused. Since I am working in inches, do I use inch lbs? If I want to apply 100 foot-lbs torque to the ring, do I use inch pounds and convert the 100 foot-lbs to 1200 inch-lbs?
Now, I am applying a torque of 1200 inch-lbs to a threaded ring with a od of 1.75 which is a .875 radius. If I divide 1200 inch-lbs by .875", I get 1371 lbs. Is this correct? Do I then multiply the 1371lbs by the mechanical advantage of 56 which is 76,776 lbs? This seems very high. I still think I am missing something when trying to get a linear force from a know applied torque.
Again, I am using a threaded ring as a example. The ring can be screwing onto a threaded rod that is welded onto a plate and the ring will butt up against the plate and I simply want to know how much linear force I am pulling on this threaded rod.
Thanks for any input.
PLease explain. The mechanical advantage of he thread is correct. If I have a 1.50"-12 stub acme thread.
thd diameter X Pi / lead(distance between thds)
1.50 ∏ / .0833 = 56
which is the same as 2∏r/lead that is shown in the link you provided
My actual question was if I have a ring(or nut) with a 1.50-12 thread and the od of the ring is 1.75", and I want to see what kind of linear force I generate from applying 100ft-lbs to the od of the ring, do I use inch pounds (100 x 12=1200 inch lbs)
.875" is the distance from center or radius
1200 in-lbs /.875 =1371lbs
Then I multiply this by the mechanical advantage of 56, this comes to 76,776 lbs
Im not an engineer. I am not even that good in math. I work in QC and ask too many questions. One of our mechanical engineers at work quickly explained to me why he made a change on his design. He quickly explained it to me. I just wanted to know if I understood it. My question was more about the torque to linear force than anything. The MA created by the thread was just something else that I had to show because it was also a variable. I just like to problem solve to my abilities. I posted this to find out if I totally missed the boat, or if I am close.
Again, all feedback is welcome.
The screw thread acts like a ramp - so a small force can lift a larger force.
Although the applied force gets amplified a great deal, it is at the expense of speed ...
The calculation is correct for the given details.
The link I gave you spells it out.
thank you Simon. I should have described the threaded rod sliding inside of another tube. The threaded rod is keyed to the tube so it cannot turn. So when torque is applied to the nut, it pulls the threaded rod thru the outer tube. The force that the calculations were giving me seemed so high (76,776 lbs), I didnt think it could be correct. My confusion was based mostly around if I was using inch pounds and converting the torque to a linear force. I find this stuff to be fun.
It would definitely crack a nut.
Explains why a vice is so strong.
it is pretty shocking - 12 turns an inch is not all that fine ... but I would imagine that applying that torque risks stripping the thread.
Related to Torque to linear force conversion and units
1. What is torque and linear force?
Torque is a measure of the twisting force on an object, while linear force is the force applied in a straight line.
2. How do you convert torque to linear force?
To convert torque to linear force, you can use the formula F = r x T, where F is the linear force, r is the distance from the center of rotation to the point of force application, and T is the torque.
3. What are the units for torque and linear force?
Torque is typically measured in newton-meters (Nm) or foot-pounds (ft-lb), while linear force is measured in newtons (N) or pounds (lbs).
4. Why is it important to convert torque to linear force?
Converting torque to linear force is important in engineering and physics because it allows for the calculation of the amount of force needed to produce a certain amount of torque, or vice versa. This is necessary for designing and analyzing various mechanical systems.
5. Are there any other factors that affect the conversion from torque to linear force?
Aside from the distance and torque, the conversion from torque to linear force can also be affected by the direction of the force, as well as any external forces acting on the system. It is important to consider all of these factors when converting between torque and linear force.
