Torque: using modified balistic pendulum with spring
In summary, the professor dropped this on us without covering it in class and the student is having trouble figuring out how to solve for the torque equation. They are looking for any help or hints that they can get.
aphophis
Hi everyone i really need help with this, unfortunately my "signals and systems" professor dropped this on us without even covering it in class. From my earlier physics class i can solve for theta in a ballistic pendulum, but since this one has a string attached to it, i really have no clue how to write the torque equation for this.
Please any help or hints will be appreciated. Thanks
Quesion:
http://mywebpage.netscape.com/Drago%20Musilini/untitled1.JPG
A pendulum is initially at rest. It is fixed to a horizontal axis by a rigid rod length of l= 100cm (both masses of the axis and rod are negligible). A spring of torsional stiffness K=196n*m/rad and a torsional dashpot of damping coefficient B=88.54n*m*sec/rad have been connected to the axis. A bullet of mass m=100g traveling with a speed v is fired into the pendulum with a bob mass M = 19.9 kg at time t = 0 and remains lodged therein.
1.Find the differential equation relating the angular displacement θ to the input v. What is the order of the system? Determine the state and output equations in matrix form. Use Matlab to find and plot the unit impulse response and determine the total output response for the inputs of v(t): 200 m/s and 800 m/s
2.Discretize the system and repeat question 1.
What have you got so far?
What is the differential equation of motion without the spring and damping? Then add the spring and damping. Assume the bullet takes a very short time to stop in the block so that the initial angular velocity is:
[tex]v_0/R = \dot\theta_0 = \frac{mv_b}{R(m+M)}[/tex]
AM
so far i was able to get the final velocity of the system as
[tex]\frac{M+m}{2g} v_b^2 = (M+m) h [/tex] where h = l(1-cos θ)
therefore [tex] v_b^2 = 2 g l (1-cos theta) [/tex]
Try analysing the forces on the block tangential to the rod:
Gravity:
[tex]F_g = - (M+m)gsin\theta \approx - (M+m)g\theta[/tex]
Spring:
[tex]F_s = - k\theta[/tex]
Dashpot damper:
[tex]F_d = - B\dot\theta[/tex]
So the torque on the system is:
[tex]F \times R = I\alpha = (F_g + F_s + F_d)R = (m+M)R^2\ddot\theta[/tex]
So set up the differential equation and use the initial condition for [itex]v_0[/itex] at time t=0.
AM
FAQ: Torque: using modified balistic pendulum with spring
What is torque and how is it related to a modified ballistic pendulum with spring?
Torque is a measure of the force that causes an object to rotate around an axis. In the case of a modified ballistic pendulum with spring, torque is the force that causes the pendulum to swing and the spring to compress.
How is the spring used in a modified ballistic pendulum to measure torque?
The spring in a modified ballistic pendulum acts as a counterbalance to the pendulum's swinging motion. As the pendulum swings, the spring is compressed, and the amount of compression can be used to measure the torque applied to the pendulum.
What are the advantages of using a modified ballistic pendulum with spring to measure torque?
One advantage of using a modified ballistic pendulum with spring is that it allows for a direct measurement of torque without the need for complex calculations. Additionally, it can be used to measure torque in a variety of scenarios, such as in the study of rotational motion or in experiments with different masses and velocities.
Are there any limitations to using a modified ballistic pendulum with spring for measuring torque?
One limitation of using a modified ballistic pendulum with spring is that it may not provide accurate measurements for very small or very large amounts of torque. Additionally, external factors such as air resistance and friction can affect the results.
How can the data collected from a modified ballistic pendulum with spring be used to calculate torque?
The data collected from a modified ballistic pendulum with spring, such as the mass and velocity of the pendulum and the amount of spring compression, can be used to calculate the torque using the equation T = I * α, where T is torque, I is the moment of inertia of the pendulum, and α is the angular acceleration.
