Deriving Torricelli's Law: Pressure, Viscosity & More
In summary, the conversation discusses the derivation of Torricelli's Law and its relationship to Bernoulli's Equation. It is explained that the equation can be derived by assuming negligible water flow and that the pressure at the bottom of the tank is equal to atmospheric pressure. However, this assumption neglects the change in pressure caused by the water flowing out of the tank. The conversation also touches on the paradox of water remaining static when the pressure at the bottom of the tank is equal to atmospheric pressure. Finally, it is mentioned that Bernoulli formulated the equation after Torricelli's death and the question of how Torricelli's Law was generalized to Bernoulli's equation is raised.
Lil_Aziz1
Hey I have a question on the derivation of Torricelli's Law. Bernoulli's Equation states the following:
Now let's say that the left side of the equation is the top of the tank and the right side of the equation is the bottom of the tank. The origin is at the bottom of the tank.
We can say that [tex]P_a = P_{atm}, v_a \approx 0, h_b = 0[/tex]
Therefore, our equation becomes
[tex]P_{atm} + pgh = P_{bottom of tank} + 1/2pv^2 [/tex]
Now torricelli's law states that [tex] v = \sqrt{2gh} [/tex], which we only get if we neglect the difference in pressure. Is that true? When I looked up torricelli's law, they said that the only thing neglected was viscosity and nothing about the change in pressure. What am I doing wrong?
Thanks in advance!
Not that i know much about fluid dynamics, but in assuming that [tex]v_a =0[/tex] you are also assuming that the amount of water flowing out of the bottom is negligible in comparison to the tank of water. Most of the water at the bottom of the tank in fact has a velocity [tex]v_b=0[/tex] and then the equation adds up. Torricelli's law is only the speed that a minute amount of water would have if you let some flow out at the bottom, not the actual velocity of all the water at the bottom of the tank.
On a second look you can actually derive Torricellis law from the equation [tex] P_{atm} + pgh = P_{bottom of tank} + 1/2pv^2 [/tex]. If you make a small hole in the tank, then the water streaming out of the tank must have a pressure [tex]P_{atm}[/tex] as well, then [tex] P_{atm} + pgh = P_{atm} + 1/2pv^2 \Rightarrow pgh = 1/2pv^2 \Rightarrow v = \sqrt{2gh}[/tex].
Oh wow I didn't think about the fact that if there is a hole, the pressure at the bottom of the tank (more specifically, the small hole) is not [tex]P=pgh[/tex]. Thanks!
hi
but
if the pressure at the bottom of the tank is equal to air pressure , it means that the pressure at the top of water and at the hole is equal to air pressure. so water cannot move and flow and must remain static.
this is a paradox,isn't it.
please help me.
thanks
Bernoulli's equation is equivalent to conservation of energy. For any given (ideal) volume of water, the equation must hold at all times. This means that one need not be concerned about how the water leaves the container. So, applying the equation with the "a" label referring to a small volume of water at the top of the container and "b" applying to the same volume of water that has just exited the container a distance h below the level of the water, one has Pa=Pb=PAtm, va≈0 (assuming the volume of water in the container is much larger than the flow rate out of the container) hA-hb=h. After some algebra one obtains Toricelli's law. The pressure at the bottom of the container is greater than the atmospheric pressure due to the depth of the water in the container. After the water leaves the container the water in the container is no longer exerting pressure on it, which is why Pa=Pb. Note that if va=Vb=0, then the Bernoulli equation allows one to derive the pressure at a given depth, ha-hb.
"After the water leaves the container the water in the container is no longer exerting pressure on it, which is why Pa=Pb."
thank you "IsometricPion"
now there is no Paradox.
Lil_Aziz1 said:
...derivation of Torricelli's Law. Bernoulli's Equation states..
You should notice that Daniel Bernoulli formulated the equation around hundred years after Torricelli's death - so the right question could be
how the Toricceli's Law got generalised to Bernoulli's equation?
FAQ: Deriving Torricelli's Law: Pressure, Viscosity & More
What is Torricelli's Law?
Torricelli's Law, also known as Torricelli's Theorem, states that the speed of a liquid flowing out of a small hole in a container is equal to the speed of an object falling freely from the same height as the liquid level.
How is Torricelli's Law derived?
Torricelli's Law can be derived using the principles of Bernoulli's equation and the continuity equation. By equating the pressure at the surface of the liquid to the pressure at the hole, and using the conservation of mass, the equation for the speed of the liquid can be derived.
How does viscosity affect Torricelli's Law?
Viscosity, or the resistance of a liquid to flow, affects Torricelli's Law by slowing down the flow of the liquid. This is due to the fact that a more viscous liquid experiences more friction as it flows through the hole, resulting in a slower speed.
What are some real-world applications of Torricelli's Law?
Torricelli's Law has many practical applications, such as in the design of fountains, sprinkler systems, and water tanks. It is also used in the fields of fluid mechanics and hydraulics to analyze the flow of liquids through pipes and channels.
How does Torricelli's Law relate to other laws in physics?
Torricelli's Law is closely related to other laws in physics, such as the laws of motion and fluid dynamics. It can also be seen as a specific case of Bernoulli's equation, which describes the relationship between pressure and flow velocity in a fluid.
