Torsion spring force required to open a door
In summary, the door will require a force of 5lbs + (.75) = 6.25lbs to open from the handle. The angular acceleration for the net accelerating force needed to achieve the desired travel distance in 4 seconds will be around 120 degrees.
GreaseMonkey83
I have a heavy door that I am adding torsion springs too in order to make it easier for a human to open.
-The door weighs 460lbs.
-It is hinged on one side by two heavy duty hinges and uses a thrust bearing in each hinge with a friction coef. of .008
-the effective radius of the thrust bearing is 31/32"
-The door handle is 56" from the hinge
-The torsion spring will apply its force 0.75" from the hinge.
Id like to beable to pull with only 5lbf normal to the door at the door handle.
I should beable to open the door 90* in 4 seconds
Do i have enough information to estimate the amount of force needed from the torsion spring?
If so, where do i start?? thanks in advance for your help.
Welcome to the PF.
I think the other thing you need is some idea of the effective radius of the thrust bearings in the hinges. That is what you will use to calculate the frictional torque that is opposing the opening torque. The smaller the effective radius of the thrust bearings (where the frictional force & torque are generated), the lower the force required to overcome that friction.
Ah yes, good point sir. It has been added.
Perfect! Now you just need to add up the torques and sum them to zero.
Torque(spring) + Torque(handle) + Torque(friction) = 0.
Do you know how to calculate the torques from the force X distance of each? Use the right-hand rule to get the directions of the torques right (+ is up and - is down). Are you familiar how to do that? And be sure to use consistent units -- maybe convert everything into meters, kilograms, etc. (MKS).
Yes... that seems a lot easier than what I was thinking. I thought the moment of inertia of the door would have to be factored in somehow. Thanks!
Moment of inertia needs to be used to determine your angular acceleration for the net accelerating force. You say you want to open the door 90 degrees in 4 seconds, if you assume you're accelerating the door for the entire 4 seconds you can figure out how much torque (and therefore force) will be needed to achieve that acceleration and final travel distance in the time specified. That force will need to be added to your friction to determine the force needed to open it in the time required.
It may be the force to overcome inertia is much larger than the frictional force if you have good bearings...
See here: http://en.m.wikipedia.org/wiki/Angular_acceleration
Keep in mind also, this added spring force will "fight" the user when closing said door, assuming it's a one-way sort of mechanism.
Likes 1 person
Related to Torsion spring force required to open a door
1. What is a torsion spring and how does it work?
A torsion spring is a type of mechanical spring that stores energy by twisting or rotating. It works by applying torque to the spring, causing it to rotate and store energy. When the torque is released, the spring returns to its original position, releasing the stored energy.
2. How does a torsion spring help to open a door?
A torsion spring is typically installed on the hinge side of a door, and when the door is closed, the spring is compressed. When the door is opened, the spring releases its stored energy, assisting in the opening of the door. The amount of force required to open the door is determined by the tension of the spring and the weight of the door.
3. How do you calculate the force required to open a door using a torsion spring?
The force required to open a door using a torsion spring can be calculated using the equation F = kθ, where F is the force in newtons, k is the spring constant in newton-meters per radian, and θ is the angle of rotation in radians. The spring constant can be determined by the size, material, and number of coils in the spring.
4. How do you choose the right torsion spring for a specific door?
The right torsion spring for a specific door depends on the weight and size of the door, as well as the desired force required to open it. It is important to accurately measure the weight and size of the door and consult with a spring manufacturer or supplier to choose the appropriate spring with the correct force and torque specifications.
5. Are there any safety precautions to consider when using a torsion spring for a door?
Yes, it is important to always use caution when working with torsion springs, as they store a significant amount of energy. It is recommended to have a professional install or replace torsion springs, as they can be dangerous if not handled properly. It is also important to regularly inspect and maintain the springs to ensure they are functioning properly and to prevent potential accidents.
  • Mechanical Engineering
