Tossing a die till a number recurs.
  • Thread starter peripatein
In summary, The conversation is about deriving the probability function of X, the number of tosses until a result equal to one of the preceding results is obtained when a die is tossed repeatedly. The question asks for a general formula for P(X) and the experts in the conversation provide different strategies for deriving it. One member suggests a recursive strategy while another member provides a pattern for calculating the probabilities for different values of X. The conversation ends with the confirmation that the numbers in the pattern are correct and that there may not be a need for a general formula.
peripatein
880
Hi,
I would like to confirm my answer to the following question in Statistics. Hopefully one of you will be willing to provide some feedback.
A die is tossed repeatedly, until a result (1-6) equal to one of the preceding results is obtained. For instance, (3,2,4,2) is a series of tosses halted at the fourth toss (as only after that toss has a number recurred). X denotes the number of tosses till 'success' is obtained. The question asks for the probability function of X.
I wasn't sure how to come up with a general formula for P(X), but I did manage to derive the following, which, hopefully, is correct:
P(X = 2) = 1/6
P(X = 3) = (5/6)(2/6) = 5/18
P(X = 4) = (5/6)(4/6)(3/6) = 5/18
P(X = 5) = (5/6)(4/6)(3/6)(4/6) = 5/27
P(X = 6) = (5/6)(4/6)(3/6)(2/6)(5/6) = 25/324
P(X = 7) = 5! / 6^5 = 5/324
Is it correct? How may I come up with a general formula for P(X)? I'd appreciate any comments and your assistance.
I'm a novice here.
Wouldn't P(X = 2) = 1/6 * 1/6 = 1/36 ?
Since you have to toss 2 times and the result obtained in the second toss has to be the same as the first toss.
Ash L said:
I'm a novice here.
No, his numbers are correct. It doesn't matter what the first toss gives. Once it has been done, there is 1/6 probability of the second toss matching it
But you have a probability of 1 to obtain any number between 1-6, and then a probability of 1/6 to obtain the same number when you toss it the second time. That's my rationale in any case.
I didn't see your post, LCKurtz, when I wrote that. Sorry.
Are all the numbers in my answer correct, i.e. for all values of X? Moreover, is there a way to derive a general formula?
No problem, that happens all the time. I worked it a different way and got the same answers you have. Dunno about a general formula. Do you really need one?
Oh ok, I misread the question.
Possibly not, I simply presumed it might be feasible to derive one and work it out more elegantly by sheer substitution for X.
It's easy enough to work out a recursive strategy. P(n) is the probability you haven't already stopped (so one minus the sum of the previous P(i)) times the probability of matching (n-1)/6.
Yes, they are correct. Your own pattern can be written as$$
P(X=k)=\frac{5!(k-1)}{6^{k-1}(7-k)!}$$for ##k=1..7##.
FAQ: Tossing a die till a number recurs.
What is the probability of getting a specific number after tossing a die till a number recurs?
The probability of getting a specific number after tossing a die till a number recurs is always 1/6, as each number on a die has an equal chance of appearing on any given roll.
What is the expected number of tosses required for a number to recur?
The expected number of tosses required for a number to recur is 6, as this is the average number of tosses needed to see all six numbers on a die. However, this is not a guarantee and it is possible for a number to recur on the first or second toss.
Is it possible for a number to never recur after an infinite number of tosses?
No, it is not possible for a number to never recur after an infinite number of tosses. This is due to the nature of probability, where the chances of a specific number appearing increase as more tosses are made.
What is the significance of the concept of "recurs" in this scenario?
The concept of "recurs" in this scenario means that a number will eventually repeat or reappear after a certain number of tosses. This is an important idea in probability as it helps us understand the likelihood of certain outcomes.
Can the concept of "tossing a die till a number recurs" be applied to other scenarios?
Yes, the concept of "tossing a die till a number recurs" can be applied to other scenarios, such as flipping a coin until a specific side appears or drawing cards from a deck until a specific suit appears. This concept can be used to understand the probability of specific outcomes in various situations.
