- #36
jim hardy
Dearly Missed
- 9,832
- 4,896
Also, the XC and XL load as you described form a series resonant circuit.
I thought quite a while on this.
MilesYoung is right
but I had to dig clear back to 1963 to get at the nuts&volts explanation. Seek time on this old gray drive ain't what it used to be...
observe that each of my two ohm impedances is paralleled by a transformer winding of pretty low impedance. So it's not quite your typical series resonant circuit.
My L and C are driven individually by fixed voltage sources.
Contrary to that a series resonant circuit is driven by a single voltage source.
In a series resonant circuit the individual L and C voltages are equal and opposite, but not fixed by the source the way they are in our circuit.
In fact in a series resonant each will be (source volts) X Qof circuit , where Q = X/R.
The voltage gain of a series resonant circuit is real and can wreck big equipment where low resistance makes for a small denominator ergo high Q.
Recall that in a series resonant circuit the voltages across the L and C become equal in amplitude but opposite in phase.
Hence each can become far larger than the source voltage,
but they cancel out,
So terminal voltage remains low while current goes sky high.
Ohm's law holds, voltage across the capacitor and voltage across the inductor is I X Z and is huge but because they're 180° out of phase they cancel. You'd have to measure them separately.
But in our circuit the voltage across each element is fixed by the transformer winding.
So voltage cannot rise. So neither can the current. So they're not resonating even though it looks like they should.
They would resonate if you removed the connection from their junction to transformer centertap .
Maybe MilesYoung can summarize this one as nicely as he did the previous one !
old jim
