Total Angular Momentum of an odd-parity shell-model state
In summary, the maximum number of nucleons for an odd-parity shell-model state is 4 and 6 respectively. For the state with 4 nucleons, the values of J and L are 3/2 and 1, and for the state with 6 nucleons, the values of J and L are also 3/2 and 1. The spin of the nucleus is equal to the j value of the unpaired nucleon and the parity is (−1)l, where l is the orbital angular momentum of the unpaired nucleon. For odd-odd nuclei, the total spin is the sum of the angular momenta of the unpaired proton and neutron, and the parity is given by (−
says
594
A certain odd-parity shell-model state can hold up to a maximum of 4 nucleons. What are its values of J and L? What about an odd-parity shell-model state with a maximum of 6 nucleons?
Parity = (-1)L
J = L+S
Total angular momentum, J, is equal to orbital angular momentum, L, plus spin, S.
Nucleons are both fermions and have spin = 1/2
Therefore, J = L + 1/2
Parity is odd ∴ L has to be an odd number (Parity = (-1)L)
maximum of 4 nucleons: 1s1/2 shell is full for either protons or neutrons. 1p3/2 shell is not full.
∴ J= 3/2
3n + 1p OR 1n + 3p
J = L ± 1/2 = 1 + 1/2 → J = 3/2, L=1
1s1/2+1p3/2 shells have maximum of 6 nucleons. ∴ L = 1
With 6 nucleons: 1s1/2 shell is full for both protons and neutrons. 1p3/2 shell is not full.
L=1
Odd A nuclei have one unpaired nucleon.
The spin of the nucleus is equal to the j value of that unpaired nucleon and the parity is (−1)l , where l is the orbital angular momentum of the unpaired nucleon.
For example, 47 Ti22 (titanium) has an even number of protons and 25 neutrons. 20 of the neutrons fill the shells up to magic number 20 and there are 5 in the 1f 7/ 2 state (l = 3, j = 7/ 2 ) Four of these form pairs and the remaining one leads to a nuclear spin of 7 /2 and parity (−1)3 = −1. •
Odd-odd nuclei. In this case there is an unpaired proton whose total angular momentum is j1 and an unpaired neutron whose total angular momentum is j2.
The total spin of the nucleus is the (vector) sum of these angular momenta and can take values between |j1 − j2| and |j1 + j2| (in unit steps).
The parity is given by (−1)(l1+l2) , where l1 and l2 are the orbital angular momenta of the unpaired proton and neutron respectively.
For example, 6 Li 3(lithium) has 3 neutrons and 3 protons. The first two of each fill the 1s level and the third is in the 1p 3 /2 level.
The orbital angular momentum of each is l = 1 so the parity is (−1)x(-1) = +1 (even), but the spin can be anywhere between 0 and 3.
see ref.http://www.personal.soton.ac.uk/ab1u06/teaching/phys3002/course/05_shell.pdf
Related to Total Angular Momentum of an odd-parity shell-model state
1. What is the total angular momentum of an odd-parity shell-model state?
The total angular momentum of an odd-parity shell-model state is the sum of the individual angular momenta of the particles within the state. It is represented by the symbol J and is a measure of the overall rotational motion of the state.
2. How is the total angular momentum of an odd-parity shell-model state calculated?
The total angular momentum of an odd-parity shell-model state is calculated by summing the individual angular momenta of all the particles within the state. This can be done using mathematical equations based on the quantum numbers of the particles, such as spin and orbital angular momentum.
3. What is the significance of the total angular momentum of an odd-parity shell-model state?
The total angular momentum of an odd-parity shell-model state is significant because it is a fundamental property of the state that affects its behavior and interactions with other particles. It can determine the stability and decay of the state, as well as its role in nuclear reactions.
4. Can the total angular momentum of an odd-parity shell-model state change?
Yes, the total angular momentum of an odd-parity shell-model state can change through various processes such as nuclear reactions or particle interactions. This can result in a different state with a different total angular momentum and behavior.
5. How does the total angular momentum of an odd-parity shell-model state affect its energy level?
The total angular momentum of an odd-parity shell-model state can affect its energy level by influencing the arrangement and interaction of particles within the state. A higher total angular momentum can result in a higher energy state and vice versa. This is important in understanding the structure and stability of nuclei.
