Total derivative involving rigid body motion of a surface
In summary, this conversation discusses the concept of rigid body transformations, specifically in regards to total derivatives. The main topic is the application of a rigid body motion to a surface and a direction vector, and the resulting changes in their normals. The conversation also touches on the physical interpretation of the partial derivative of the surface normal with respect to time.
user11443
This stems from considering rigid body transformations, but is a general question about total derivatives. Something is probably missing in my understanding here. I had posted this to math.stackexchange, but did not receive any answers and someone suggested this forum might be more suitable.
A rigid body motion consisting of ##3 \times 3## rotation ##{\mathbf{R}}## and ##3 \times 1## translation ##{\mathbf{p}}## transforms a point ##{\mathbf{x}} \in {\mathbb{R}}^3## to ##{\mathbf{R}} {\mathbf{x}} + {\mathbf{p}}##. For a small motion, the displacement of a point ##{\mathbf{x}}## is ##\Delta {\mathbf{x}} = ({\mathbf{R}} {\mathbf{x}} + {\mathbf{p}}) - {\mathbf{x}}##, which is rewritten as ##\Delta {\mathbf{x}} = {\mathbf{w}} \times {\mathbf{x}} + {\mathbf{p}}##, where ##{\mathbf{w}}## is the angular velocity using ##{\mathbf{R}} \approx {\mathbf{I}} + [{\mathbf{w}}]_\times##, with ##[{\mathbf{w}}]_\times## the infinitesimal skew-symmetric matrix.
For a surface with unit surface normal ##{\mathbf{n}}##, suppose we have a unit direction vector ##{\mathbf{s}} \in {\mathbb{S}}^2## that depends only on time ##t## and is independent of ##{\mathbf{x}}##. Consider the function ##f({\mathbf{x}}, t) = {\mathbf{n}}({\mathbf{x}}, t)^\top {\mathbf{s}}(t)##. Suppose the same rigid body motion is applied to both the surface and the direction vector ##{\mathbf{s}}##, then it transforms the surface normal to ##{\mathbf{R}} {\mathbf{n}}## and ##{\mathbf{s}}## to ##{\mathbf{R}} {\mathbf{s}}##, so their changes are given by ##{\mathbf{w}} \times {\mathbf{n}}## and ##{\mathbf{w}} \times {\mathbf{s}}##, respectively. If a point ##{\mathbf{x}}_1## on the surface at time ##t_1## moves to ##{\mathbf{x}}_2## at time ##t_2##, we must have ##f({\mathbf{x}}_1, t_1) = f({\mathbf{x}}_2, t_2)##, since ##({\mathbf{R}} {\mathbf{n}})^\top {\mathbf{R}} {\mathbf{s}} = {\mathbf{n}}^\top {\mathbf{s}}##.
The above means the total derivative of ##f({\mathbf{x}}, t)## with respect to ##t## is ##0##. However,
\begin{align}
\frac{df}{dt} &= \frac{d}{dt} {\mathbf{n}}({\mathbf{x}}, t)^\top {\mathbf{s}}(t) = {\mathbf{s}}(t)^\top (\frac{\partial {\mathbf{n}}}{\partial {\mathbf{x}}} \frac{d{\mathbf{x}}}{dt} + \frac{\partial {\mathbf{n}}}{\partial t}) + {\mathbf{n}}({\mathbf{x}},t)^\top \frac{d{\mathbf{s}}}{dt} \\
&= {\mathbf{s}}(t)^\top \frac{\partial {\mathbf{n}}}{\partial {\mathbf{x}}} ({\mathbf{w}} \times {\mathbf{x}} + {\mathbf{p}}) + {\mathbf{s}}(t)^\top ({\mathbf{w}} \times {\mathbf{n}}) + {\mathbf{n}}({\mathbf{x}},t)^\top ({\mathbf{w}} \times {\mathbf{s}}) \\
&= {\mathbf{s}}(t)^\top \frac{\partial {\mathbf{n}}}{\partial {\mathbf{x}}} ({\mathbf{w}} \times {\mathbf{x}} + {\mathbf{p}}).
\end{align}
So, we have that ##{\mathbf{s}}(t)^\top \displaystyle\frac{\partial {\mathbf{n}}}{\partial {\mathbf{x}}} ({\mathbf{w}} \times {\mathbf{x}} + {\mathbf{p}})## must be ##0##, for any choice of ##{\mathbf{s}}##, ##{\mathbf{w}}## and ##{\mathbf{p}}##. Something seems to be wrong here, since ##\displaystyle\frac{\partial {\mathbf{n}}}{\partial {\mathbf{x}}}## is a property of the surface, independent of ##{\mathbf{s}}##, ##{\mathbf{w}}## and ##{\mathbf{p}}##. Can someone see what is incorrect in the above?
It is the total derivative of ##\vec n## that is given by ##\vec w \times \vec n##, not the partial derivative wrt ##t##.
Thanks Orodruin. Is there a physical interpretation to the partial derivative of the surface normal with respect to time? Or in other words, it seems from applying the chain rule for ##\displaystyle\frac{d{\mathbf{n}}}{dt}## that
\begin{equation}
\frac{\partial {\mathbf{n}}}{\partial {\mathbf{x}}} \frac{d{\mathbf{x}}}{dt} + \frac{\partial {\mathbf{n}}}{\partial t} = {\mathbf{w}} \times {\mathbf{n}}.
\end{equation}
But I am having a hard time seeing how the two things above turn out to be equal.
The partial derivative of n wrt time is the change in the normal at a given point in space. Since the normal is defined only on a surface, this derivative may not even make sense (you could extend the definition of n to the full volume by considering normal unit vectors to a family of non-intersecting surfaces, such as the level surfaces of some function). When it does make sense, you will find that this changes depending on the surface as well as the rotation.
Thanks, Orodruin.
Related to Total derivative involving rigid body motion of a surface
1. What is a total derivative involving rigid body motion of a surface?
A total derivative involving rigid body motion of a surface refers to the change in a function with respect to changes in both its input variables and the orientation of the surface on which it is defined. In other words, it takes into account the movement or rotation of the surface itself, in addition to changes in its input variables.
2. What is the significance of calculating a total derivative involving rigid body motion of a surface?
Calculating a total derivative involving rigid body motion of a surface is important in understanding how the behavior of a function changes when the surface on which it is defined is also moving or rotating. This is particularly relevant in fields such as fluid mechanics, where surfaces are often in motion.
3. How is a total derivative involving rigid body motion of a surface calculated?
A total derivative involving rigid body motion of a surface can be calculated using the chain rule, where the partial derivatives of the function with respect to the input variables and the surface orientation are multiplied together. It can also be calculated using the concept of directional derivatives.
4. What is the difference between a total derivative involving rigid body motion of a surface and a regular total derivative?
The difference between a total derivative involving rigid body motion of a surface and a regular total derivative is that the former takes into account changes in the surface orientation, while the latter only considers changes in the input variables. This means that a total derivative involving rigid body motion of a surface is more comprehensive and provides a more accurate understanding of the behavior of a function.
5. In what fields of science is the concept of total derivative involving rigid body motion of a surface commonly used?
The concept of total derivative involving rigid body motion of a surface is commonly used in fields such as fluid dynamics, aerodynamics, and structural engineering. It is also relevant in other areas of science that involve moving or rotating surfaces, such as planetary motion and robotics.
  • Mechanics
