Total electrical resistance flux
In summary, the circular wire loop with 10 turns and a radius of 1.0 cm has a total electrical resistance of 0.10 Ω. The magnitude of the magnetic field near the wire loop, due to the solenoid, is 0.002 T at t = 0 s. The current through the solenoid doubles between t = 2 s and t = 4 s. To find the magnitude of the rate-of-change of the magnetic flux through the wire loop at t = 3 s, the relationship between magnetic flux and current must be determined. Assuming a linear change in current over time, the flux can be calculated by multiplying the initial value of 6.28E-6 Wb
yitriana
36
The circular wire loop has 10 turns and a radius of 1.0 cm. The total electrical resistance of the 10 turn loop is 0.10 Ω. The magnitude of the magnetic field due to the solenoid near the wire loop at t = 0 s is 0.002 T. The current through the solenoid doubles between t = 2 s and t = 4 s.
What is magnitude of the rate-of change of the magnetic flux through the wire loop at t = 3 s?
flux = NBA where N is number of turns of wire, B is magnetic field, A is area traversed by one loop
E = IR where E is induced emf on the wire
I have calculated the flux accurately 6.28E-6 Wb, but I am having a lot of difficulty with the bolded question. I can't figure out how to manipulate the equations because I don't know the initial current, and I don't know the final magnetic field and I just can't simplify anything.
How is the magnetic flux related to the current in the solenoid? By this I mean, is it directly proportional, inversely proportional, goes as the square of the current or what? If you can answer this question, then you can figure out by what factor the flux changes from t = 2 to t =3 s and then all you have to do is multiply the 6.28e-6 Wb by that factor to find the flux. Unless you have a figure that shows otherwise, you may assume that the current changes linearly with time.
I understand your struggles with this problem. In order to calculate the rate of change of the magnetic flux through the wire loop at t = 3 s, we can use Faraday's Law, which states that the induced emf (E) in a closed loop is equal to the negative rate of change of the magnetic flux through that loop. In this case, the induced emf can be calculated using Ohm's Law (E = IR), where R is the total electrical resistance of the loop.
Since the current through the solenoid doubles between t = 2 s and t = 4 s, we can use the known resistance of the loop (0.10 Ω) to calculate the initial current at t = 2 s. Then, using the known increase in current, we can calculate the final current at t = 4 s.
Once we have the initial and final currents, we can use the equation B = μ0nI, where μ0 is the permeability of free space, n is the number of turns per unit length (in this case, n = 10 turns/length of the solenoid), and I is the current. This will give us the initial and final magnetic fields at t = 2 s and t = 4 s, respectively.
Now, using the known area of the loop (A = πr^2, where r is the radius of the loop), we can calculate the initial and final flux values at t = 2 s and t = 4 s. Finally, we can use the formula for average rate of change (Δflux/Δtime) to calculate the magnitude of the rate of change of the magnetic flux through the wire loop at t = 3 s.
I hope this helps you to solve the problem and better understand the concepts involved. Keep in mind that in science, it is important to approach problems systematically and use known equations and principles to solve them. Good luck!
FAQ: Total electrical resistance flux
What is total electrical resistance flux?
Total electrical resistance flux, also known as total electrical resistance, is a measure of the overall resistance to the flow of electric current in a circuit. It takes into account the resistance of all components in the circuit, including wires, resistors, and other elements.
How is total electrical resistance flux calculated?
Total electrical resistance flux is calculated using Ohm's Law, which states that the total resistance in a circuit is equal to the voltage divided by the current. It can also be calculated by adding the individual resistances of each component in the circuit.
What factors affect total electrical resistance flux?
The factors that affect total electrical resistance flux include the type and length of wires used in the circuit, the material and size of resistors, and the temperature of the circuit. The resistance of a material also plays a role, with materials such as copper having lower resistance compared to materials like steel.
Why is total electrical resistance flux important?
Total electrical resistance flux is important because it determines the amount of current that can flow through a circuit. A higher resistance means less current can flow, while a lower resistance allows for more current. It also affects the performance and efficiency of electrical systems.
How can total electrical resistance flux be reduced?
Total electrical resistance flux can be reduced by using materials with lower resistance, such as copper instead of steel, and by using thicker wires and larger resistors. Additionally, minimizing the length of wires and keeping the temperature of the circuit low can also help reduce resistance.
