Total energy of charge in parallel plate capacitor
In summary: Thank you.In summary, the conversation discusses finding the total energy of a charge placed at the left plate of a parallel plate capacitor when the left plate is at 0V and the right plate is at V0, with the plates a distance L apart. The equation used is Etot = 1/2 mv2 + qφ(x) and φ(x) = Vx/L, and the total energy is found to be 0, with the charge moving towards the right plate as it has a negative charge. The equation for the potential, Φ(x) = Vx/L, is derived using boundary conditions and Poisson's equation in space.
Inquisitive Student
Find the total amount of energy of a charge (q) initially at rest placed at the left plate of a parallel plate capacitor. The left plate is at V = 0, the right plate at V = V0 and the plates are a distance L apart.
Etot = 1/2 mv2 + qφ(x).
φ(x) = Vx/L
Since energy is conserved:
E = Einitial = 1/2 m(vinitial)2 + qφ(0) = 0 + 0 = 0.
(I chose x = 0 to be the left plate)
So the total energy that the charge has is 0 everywhere? How does the charge even move at all if it has no energy to begin with?
Remember that the electric potential is invariant under addition of a constant. All that matters is how the potential changes with distance. Since ##E_{tot}## is related to how the potential is defined, the total energy is an arbitrary constant. Here, you are using the convention that the potential is zero at the surface of the left plate. Since the kinetic energy at this location is also zero, the total energy is a constant zero. The kinetic energy however, is not constant as the charge moves.
The charge will move in the direction of decreasing potential. If ##q## is negative, this means the charge will move towards the right plate. As this happens, the kinetic energy must increase to preserve the total energy and keep ##E_{tot}=0##.
Likes conscience
φ(x) = Vx/L
Please explain this equation and how you are using it (if you are). If you are not, how do you get that Φ(x)=0?
From boundary conditions we know that Φ(x = 0) = 0 (stated in the problem that left wall of parallel plate capacitor is at Φ = 0) and that Φ(x = L) = V. Poisson's equation in space (we neglect the charge in the problem, we are just finding the potential due to the walls) is ∇2Φ = 0, or in 1D: $$\frac{\partial^2 Φ}{ \partial x^2} = 0$$. Since the second derivative is equal to 0, that means the first derivative was equal to a constant. So, $$\frac{\partial Φ}{\partial x} = c$$, where c is a constant. We can solve this differential equation by integrating, $$\frac{\partial Φ}{\partial x} = c$$ becomes ∫∂Φ = ∫c ∂x, which means $$Φ(x) = cx + c_1$$ where c1 is a constant that came from integration. Now plugging in the boundary conditions:
Φ(0) = 0 gives c1 = 0
Φ(L) = V gives v = c*L or c = v/L
So in total we get: Φ(x) = cx = vx/L
If you mean Φ(L)=V0, yes, Φ(x)=V0x/L gives the potential as a function of distance from the left plate, valid for all points between the plates. I was thrown by the reference to V instead of V0.
So does NFuller's response answer your question?
Yeah, NFuller had a very clear response. It was really helpful.
Related to Total energy of charge in parallel plate capacitor
1. What is the formula for calculating the total energy of a charge in a parallel plate capacitor?
The total energy of a charge in a parallel plate capacitor can be calculated using the formula U = 1/2 * Q^2 / C, where U is the energy in joules, Q is the charge in coulombs, and C is the capacitance in farads.
2. How is the total energy affected by the distance between the plates in a parallel plate capacitor?
The total energy of a charge in a parallel plate capacitor is directly proportional to the distance between the plates. As the distance between the plates increases, the energy also increases. This is because the capacitance (C) decreases as the distance between the plates increases, resulting in a larger value for the total energy.
3. Does the total energy of a charge in a parallel plate capacitor depend on the charge or potential difference?
Yes, the total energy of a charge in a parallel plate capacitor is directly proportional to the square of the charge (Q) and inversely proportional to the potential difference (V) between the plates. This can be seen in the formula U = 1/2 * Q^2 / C, where C = Q/V.
4. How does the dielectric material between the plates affect the total energy of a charge in a parallel plate capacitor?
The dielectric material between the plates of a parallel plate capacitor can affect the total energy in two ways. First, it can increase the capacitance, which in turn increases the total energy. Second, it can decrease the electric field strength, resulting in a smaller potential difference and therefore a smaller total energy.
5. Is the total energy of a charge in a parallel plate capacitor conserved?
Yes, the total energy of a charge in a parallel plate capacitor is conserved. This means that the energy cannot be created or destroyed, but it can be transferred between different forms, such as electrical energy and potential energy.
