Total entropy change for ice melting in a room
In summary, the conversation discusses the concept of entropy and a specific question about determining the total entropy change for 7 kg of ice melting from -5 C° to 5 C° in a room at 5 C°. The conversation covers different equations and considerations for calculating entropy, including the specific heat of ice and water, the change in entropy during phase changes, and the assumption that the temperature of the room air does not change significantly.
plpg
Okay, so I am having difficulties with understanding the concepts around entropy, take this question:
What is the total entropy change for 7 kg of ice melting from -5 C° to 5 C° in room at 5 C°.
dS=dQ/T
Q =mΔH
m*c*ln(tfinal/tinitial)
c_ice=2
c_water=4
c_air=1
Okay, so this is my reasoning so far:
as the ice heats up to zero centigrades, the total change in entropy is given by integrating dS=dQ/T wrt T, and we end up at : m*c*ln(tfinal/tinitial), so 7*2*ln(273.15/(273.15-5)) j/k.
As the ice changes its state to water, the change in entropy is given directly by dS=dQ/T, where dQ is =mdH=7*330=2310 j/k.
When the water heats up from 0 centigrades to 5 centigrades its change in entropy is again given by, 7*4*ln(273.15+5/(273.15)) j/k,
and adding these we get the total entropy change for the melting ice.
Now to the part that I am having big difficulties understanding: the change in entropy of the room. I've read that it is given by m*c_air*((tfinal-tinitial)/tfinal), so in this case this would be negative 7*1*((273.15+5°-(273.15-5°))/(273.15+5°)) j/k.
So adding all these would give me the answer? 7*2*ln(273.15/(273.15-5)) j/k + 2310 j/k + 7*4*ln(273.15+5/(273.15)) j/k - 7*1*((273.15+5°-(273.15-5°))/(273.15+5°)) j/k.
Am i even close to getting this question right?
This is correct except for the units. What are the units for the specific heat of ice?
Again, correct except for the units.
Units.
You have to assume that the temperature of the room air does not change. The room is large enough that the heat flow from the air changes the temperature of the air by a negligible amount. So the entropy change is just[itex]\Delta S_{room} = \Delta Q_{room}/T_{room}[/itex] where [itex]\Delta Q_{room} = - \Delta Q_{ice}[/itex].
AM
plpg said:
Thank you for your reply. I make the units out to be Joule per kelvin, is that something i should look more into or was it the fact that I wrongly used small j and k?
If you are using Kg and a specific heat of 2 KJ/Kg for ice and 4 KJ/Kg for water (which I assume is the case since you are using 7 and not 7,000 as the mass), the units for entropy will be in KJ/K.
"You have to assume that the temperature of the room air does not change. The room is large enough that the heat flow from the air changes the temperature of the air by a negligible amount." Aha okay, So the total change in entropy ought to be more in the lines of :
S_total=S_Ice-(ΔQ_ice/T_room)
Correct so far.
= (7*2*ln(273.15/(273.15-5))+ 2310+ 7*4*ln(273.15+5/(273.15)))J/K - (ΔQ_ice/(273.15+5)) ?
Where ΔQ_ice=mc_iceΔT+mΔH+mc_waterΔT i.e the total energy required to heat 7 kg of ice from -5c° to 5c° ?
If you are using mass in Kg, the specific heat is in units of KJ/Kg. For example, the total heat flow required to melt 7kg of ice is 7*330 KJ = 2310 KJ = 2,310,000 J.
AM
plpg said:
Please remove, I see that there are many similar threads already on this.
plpg said:
1234
Cheating by deleting your posts after you have received help is strictly against the PF rules. Check your PMs, and do not do this again here.
Related to Total entropy change for ice melting in a room
1. What is total entropy change for ice melting in a room?
The total entropy change for ice melting in a room refers to the overall change in the amount of disorder or randomness in the system as ice melts into liquid water in a specific space or environment.
2. How is total entropy change for ice melting in a room calculated?
The total entropy change for ice melting in a room can be calculated using the formula ΔS = Q/T, where ΔS is the change in entropy, Q is the heat transferred during the melting process, and T is the temperature.
3. What factors affect the total entropy change for ice melting in a room?
The total entropy change for ice melting in a room is affected by the initial temperature of the ice, the temperature of the room, and the amount of heat transferred to the system during the melting process.
4. Why is total entropy change important in the process of ice melting in a room?
The concept of total entropy change is important in the process of ice melting in a room because it helps us understand the overall change in disorder and energy as ice changes state into liquid water. It also allows us to predict and control the amount of heat needed for the ice to melt in a specific environment.
5. How does the total entropy change for ice melting in a room relate to the second law of thermodynamics?
The total entropy change for ice melting in a room follows the second law of thermodynamics, which states that the total entropy of an isolated system will always increase over time. In the case of ice melting in a room, the entropy of the system (ice and room) increases as the ice changes state and becomes more disordered.
