Total force generated in a pneumatic cylinder-piston with kn
In summary, the conversation discusses the best model to describe the total steady state force applied on a pneumatic cylinder-piston, taking into consideration the leakage of air. The desired equation is in the form of $F=f\left(P_1,A,L,c\right)$, with extreme cases being hydrostatic pressure when c approaches 0 and air drag when c is large. The speaker mentions being able to calculate leakage but not knowing how to proceed from there. It is noted that when the system is in steady state condition, the pressure and force are equal, while in transient condition, the force can be approximated as (P1 - P0 at time t) x A. The value of P0 can be determined using standard air
foadsf
I have also asked this question in SO and CFD online
Assuming that we have a pneumatic cylinder-piston with arbitrary but known surface area A, a known clarence c, and a known length L. What is the best model to describe the total steady state force applied on the piston considering the leakage? (the force required to keep the piston in place)
What I'm looking for is an equation in the form of $F=f\left(P_1,A, L, c\right)$. In extreme cases:
- if ## c\rightarrow 0 ## then ##F=P_1A## is just hydrostatic pressure
- if c is big then ##F\approx \frac{1}{2}\rho\nu^2C_DA## is just air drag
I can calculate leakage from empirical or theoretical models but I don't know how to proceed from there.
Given that the piston is not moving and that there is at least some leakage of air possible around the piston then :
When the system is in steady state condition P0 = P1 and F = 0
When the system is in transient condition P0 is initially < P1 but increases with time as air flows around the piston . To a good approximation at any time t during this transient period F = (P1 - P0 at time t) x A .
The value of P0 at time t can be determined using standard air flow calculation methods .
You could calculate the viscous air drag force on the piston at time t as well but it is likely to be insignificant in many practical cases .
Related to Total force generated in a pneumatic cylinder-piston with kn
1. What is a pneumatic cylinder-piston?
A pneumatic cylinder-piston is a device that uses compressed air to create linear motion, typically used in a variety of industrial and manufacturing processes.
2. How is the total force generated in a pneumatic cylinder-piston?
The total force generated in a pneumatic cylinder-piston is a result of the pressure and area of the piston. As air is compressed into the cylinder, it creates pressure that pushes against the surface area of the piston, resulting in a force.
3. What are the main components of a pneumatic cylinder-piston?
The main components of a pneumatic cylinder-piston include the cylinder itself, the piston, a rod attached to the piston, seals to keep the air contained, and ports for air intake and exhaust.
4. How does the size of the piston affect the force generated?
The size of the piston directly affects the force generated in a pneumatic cylinder-piston. A larger piston will have a larger surface area, resulting in a greater force being generated when air is compressed into the cylinder.
5. What is the importance of the kn value in a pneumatic cylinder-piston?
The kn value, or the force constant, is a measurement of the force generated per unit of pressure in a pneumatic cylinder-piston. It is important to consider this value when selecting the appropriate pneumatic cylinder for a specific application to ensure that the necessary force can be generated.
  • Mechanical Engineering
12K
30K
