Total Internal Reflection Confusion
In summary, the conversation discusses the concept of critical angle in relation to total internal reflection. The critical angle is defined as the minimum angle at which total internal reflection occurs, and it determines the index of refraction of the glass. A larger angle would still demonstrate total internal reflection, but it would not be the critical angle. The correct answer to the given problem is option c).
jegues
1,097
See figure attached.
Initially,
[tex]\theta_{c} = 60^{o}[/tex]
[tex]n_{glass}sin\theta_{c} = n_{air}[/tex]
So,
[tex]n_{glass} = \frac{n_{air}}{sin\theta_{c}}[/tex]
Now I would think that the incident angle from glass to air would be able to get LARGER and still remain critical because it would be less "head on" to the incident surface and thus less likely to refract through.
So if we assume, [tex]\theta_{c}[/tex] can get larger and still remain critical then if we take and angle say,
[tex]\theta_{c} = 85^{o}[/tex]
certainly,
[tex]n_{glass} = \frac{n_{air}}{sin\theta_{c}} < 1.15[/tex]
because the value of the denominator is getting larger.
However they give c) as the correct answer. What am I misunderstanding?
Think of it this way. Since the angle shown demonstrates total internal reflection, the critical angle must equal that or less. So that defines a minimum value for the index of refraction of the glass.
Surely a larger angle would still demonstrate total internal reflection, but that larger angle would not be the critical angle.
This is much more clear, thank you.
Related to Total Internal Reflection Confusion
1. What is total internal reflection confusion?
Total internal reflection confusion occurs when light rays are completely reflected back into a medium instead of passing through it, causing a distorted or unclear image.
2. What causes total internal reflection confusion?
Total internal reflection confusion is caused by a change in the refractive index of a medium, resulting in light being unable to pass through the boundary between two mediums.
3. How can total internal reflection confusion be prevented?
Total internal reflection confusion can be prevented by using anti-reflective coatings or materials with a lower refractive index, such as glass or water, to reduce the change in refractive index at the boundary.
4. What are some real-life examples of total internal reflection confusion?
Some real-life examples of total internal reflection confusion include mirages, the "shimmering" effect on hot surfaces, and the "spotlight" effect on diamonds and other gemstones.
5. Why is total internal reflection confusion important to understand?
Total internal reflection confusion is important to understand because it can impact the quality and accuracy of optical devices such as lenses and mirrors, and can also affect the appearance of objects in certain conditions.
