Total Internal Reflection / Reflection. What's the answer
In summary: The image is quite symmetric about the horizontal axis. There is no asymmetry which would suggest an eye position much below the water line. That would support the idea that this is TIR. However, there are no good distance cues, so we cannot accurately judge the viewing angle for the bottom of the lake or river bed, the bottom-most portion of which is not even present in the reflected image.
SunandaGoh
https://scontent-kul1-1.xx.fbcdn.net/v/t35.0-12/15146781_1334186669946177_363846788_o.jpg?oh=b75be99f63eba2e70db5e0287581076b&oe=583538C2
The answer given by the book is " Reflection ". But why isn't it Total Internal Reflection ?
Total internal reflection occurs only at specific range of angle of incidence. Moreover, is "total internal reflection" among the choices?
The choices are
A. Reflection
B. Refraction
C. Diffraction
D. Total Internal Reflection.
The diagram is a bit off. You would not see the water surface as a line, and the reflection would not look exactly like the directly viewed animal.
The head is so near the surface it would certainly be total internal reflection, and the rest of the reflection is shown as being as strong, suggesting it is all TIR.
Likes SunandaGoh
It is difficult to know how much of the depiction to take as realistic and how much to take as illustrative. For instance, the entire reflection is less "strong" than the directly viewed image. That could be taken as a meaningful tidbit of information or it could be taken as artistic license to more clearly delineate between directly viewed image and reflection. As @haruspex points out, the head is depicted as strongly as the rest, so one is forced to a conclusion that it is artistic license.
For me it is the lack of reliable information about the viewing angle for the extreme top of the image which leads to the conclusion that "reflection" is the desired answer.
The throat and belly are facing away from the interface yet appear in the image. It is difficult to see how a simple reflection could reveal the creature's underside here.
Related to Total Internal Reflection / Reflection. What's the answer
What is total internal reflection?
Total internal reflection is a phenomenon that occurs when a light ray traveling in a denser medium reaches the boundary of a less dense medium at an angle greater than the critical angle. Instead of refracting, the light ray reflects back into the denser medium.
What is the critical angle?
The critical angle is the angle of incidence at which total internal reflection occurs. It is dependent on the indices of refraction of the two mediums involved.
What are some real-life applications of total internal reflection?
Total internal reflection has many practical applications, such as in fiber optics for telecommunications, endoscopes for medical procedures, and prisms in binoculars and cameras.
How is total internal reflection different from regular reflection?
Regular reflection occurs when a light ray hits a smooth surface and is reflected at the same angle as the incident angle. Total internal reflection only occurs when the light ray reaches a boundary between two mediums at a specific angle.
Can total internal reflection occur with any type of light?
Yes, total internal reflection can occur with any type of light, including visible light, infrared radiation, and ultraviolet radiation. It is dependent on the angle of incidence and the indices of refraction of the mediums involved.
