Total Mechanical Energy Swing Problem
In summary, the conversation discusses a child on a swing being pushed with 75 J of work and the calculation of their kinetic energy at position A. It is also mentioned that the child has potential energy and the equation for it is PE = mgh. The initial kinetic energy is determined to be 75 J, and the discussion then moves on to solving for the maximum speed and height of the child on the swing. The question is clarified, and it is determined that the work done on the child during the push is equal to their initial kinetic energy. From this, the relationship between kinetic energy and position is discussed and used to find the maximum kinetic energy and height of the child on the swing.
Snape1830
65
A 30 kg child is playing on a swing. Another child is pushing. That second child does 75 J of work on the swing. Ignore friction. The swing has zero mass compared to the child on the swing. There is a diagram. So basically: Postion A Height = .6 m. Position B Height = .2 m and Postion Height C = ?
a. How much kinetic energy does the child on the swing have at position A just after the push?
Work = change in kinetic energy. So I did 75=.5(30)(v2)-.f(30)(0) to get velocity (I assumed the initial velocity is 0) And then I was going to plug that into KE = .5mv2. Is that right?
c. What is the maximum speed of the child on the swing?
d.What is the maximum height off the ground the child on the swing reaches following the initial push.
Part b is the total energy at positions B and C. I can figure that out. I'm really just confused about c, and I want to know if that is how to do a.
Please help!
The kid on the swing has two different forms of energy. You've already said about kinetic energy, but there is another.
Potential energy.
Yep. The kid also has potential energy. Do you know the equation for it?
Yup! It's PE = mgh
That's the one. You are also given the initial height and kinetic energy, so from this you can calculate the total energy (which is a conserved quantity).
Would the initial kinetic energy be the answer I have for part a? In that case, part a is right?
I think you were right that the work done is equal to the initial KE of the kid. So I think you did get a) right. (and you don't need to find the velocity, since it only asks for the KE).
But KE=.5mv^2, so I need to find velocity before I can calculate kinetic energy.
But you're starting with the kinetic energy. So taking the extra step of solving for the velocity, then plugging it back into the same expression can only give you back what you started with.
But I never had the kinetic energy to begin with. I had work and mass, but I was never given any velocity.
But the work equals the kinetic energy. That's your first equation.
Oh I see what you're saying. Sorry! Thanks! So the kinetic energy is 75 J.
yep. That's the initial KE.
Ok, but now how do I solve part c? And also if Work = the change in kinetic energy, but 75 joules is only the initial energy, how does that work?
At least give it a try yourself. What physics principles/laws do you think might help?
Yeah, the problem is maybe a bit badly worded. It is most likely that they are saying the kid was initially at rest, then work was done on him to give him kinetic energy. So the best bet is to assume that the work done at the start is the initial KE of the kid.
The only equation that has "speed" is kinetic energy. So would I just say that 75 = .5(30)v62 and solve for v? If that's the case then I have to assume 75 J is the change in kinetic energy, not the initial kinetic energy.
No, that's not right. The question, as you wrote it in the first post, implies that the kid is pushed, and it is during this time that work is done on him. And at the end of this push, the kid is at position A.
Now I can only assume that the work done on the kid is equal to the kinetic energy of the kid at position A. This is my own interpretation of the question, but I think it is most likely what the question did mean.
So this gives you the initial KE and position of the kid. From now on, no work is being done on the kid. So how would you work out the relationship between KE and position? and how can you use this to find the max KE which the kid will have, once he goes through pendulum motion?
Well position implies height, right? Which is in the equation for PE (PE = mgh). I really just don't know. I appreciate the help, but I guess I'll just go see the teacher about this.
You're on the right track there. seeing the teacher is a good idea though.
Related to Total Mechanical Energy Swing Problem
1. What is total mechanical energy?
Total mechanical energy is the sum of potential energy and kinetic energy in a system. It represents the total amount of energy that a system possesses and remains constant as long as there are no external forces acting on it.
2. How does total mechanical energy relate to a swing problem?
In a swing problem, the total mechanical energy of the system is constant. As the swing moves back and forth, the potential energy is converted to kinetic energy and vice versa, but the total amount of energy remains the same.
3. How can total mechanical energy be calculated in a swing problem?
The total mechanical energy can be calculated by adding the potential energy and kinetic energy. The potential energy is equal to the mass of the swing times the acceleration due to gravity times the height of the swing. The kinetic energy is equal to half the mass of the swing times the square of its velocity.
4. What happens to the total mechanical energy if there is friction in a swing problem?
If there is friction present, the total mechanical energy will decrease over time as some of the energy is lost to heat and sound. This means that the swing will gradually slow down and eventually come to a stop.
5. How can total mechanical energy be conserved in a swing problem?
In order to conserve total mechanical energy in a swing problem, there must be no external forces acting on the system. This means that there should be no friction, air resistance, or other external forces that could dissipate energy. Additionally, the swing must be moving in a closed system, meaning there is no energy being added or taken away from the system.
