Total Momentum Operator for Klein Gordon Field
In summary, Peskin & Schroeder use a (+---) metric signature, where the index placement on the derivative operator is such that ##\partial^i = -\partial_i##. This means that the expression for $$P^i$$ in terms of $$T^{0i}$$ has a negative sign. Similarly, in the expression for $$\partial_i\phi$$, the sign of the momentum component is negative. However, Jakob Schwichtenberg in No-Nonsense Quantum Field Theory uses a (-+++), which means that the derivative operator has the usual index placement, and thus there is no negative sign in the expression for $$P^i$$ or $$\partial_i\phi$$.Furthermore, when using the
Samama Fahim
52
Prove that $$P^i=\int d^3x T^{0i} = -\int d^3 \pi \partial_i \phi$$
$$T_{\nu}^{\mu}=\frac{\partial\mathcal{L}}{\partial(\partial_{\mu} \phi)}\partial_{\nu}\phi-\delta_{\nu}^{\mu}\mathcal{L}$$
As
$$\hat{P_i} = \int d^3x T^0_i,$$
and
$$T_i^0=\frac{\partial\mathcal{L}}{\partial(\partial_0 \phi)}\partial_i\phi-\delta_i^0\mathcal{L}=\frac{\partial\mathcal{L}}{\partial(\partial_0 \phi)}\partial_i\phi=\pi\partial_i\phi.$$
Therefore,
$$\hat{P_i} = \int d^3x \pi\partial_i\phi.$$
However, in Peskin & Schroeder it's given with a negative sign:
$$\hat{P^i} = -\int d^3x \pi\partial_i\phi.$$
How do I go from $$T^{0}_i$$ to $$T^{0i}$$?
Does Peskin & Schroeder use a (+---) metric signature? In which case ##\partial^i \equiv - \partial_i## and\begin{align*}
P^i &= \int d^3 x T^{0i} = \int d^3 x \frac{\partial\mathcal{L}}{\partial(\partial_{0} \phi)}\partial^{i}\phi = \int d^3 x \pi \partial^i \phi = -\int d^3 x \pi \partial_i \phi
\end{align*}
Likes vanhees71, Delta2 and Samama Fahim
\end{align*}
Yes they do use the signature (+---). Why would $$\partial^i$$ become $$-\partial_i$$ in that case?
Recall that with (+---) then ##\eta = \eta^{-1} = \mathrm{diag}(1,-1,-1,-1)## and\begin{align*}
v^0 = \eta^{0j} v_j = \eta^{00} v_0 = v_0
\end{align*}whilst, for any fixed ##i = 1,2,3##,\begin{align*}
v^i = \eta^{ij} v_j = \eta^{ii} v_i = -v_i
\end{align*}
Likes Samama Fahim
\end{align*}
Could you please confirm one more thing:
If
$$\phi = \int d^3k \frac{1}{(2 \pi)^3 \sqrt{2\omega_k}} \left(a(\vec{k})e^{-i(\omega_kx_o-\vec{k}\cdot \vec{x})}+a^{\dagger}(\vec{k})e^{i(\omega_kx_0-\vec{k}\cdot \vec{x})}\right).$$
then we should have
$$\partial_i\phi=\int d^3k \frac{1}{(2 \pi)^3 \sqrt{2\omega_k}} \left(a(\vec{k})(ik_i)e^{-i(\omega_kx_o-\vec{k}\cdot \vec{x})}+a^{\dagger}(\vec{k})(-ik_i)e^{i(\omega_kx_0-\vec{k}\cdot \vec{x})}\right).$$
Is that correct?
That looks fine to me.
Likes Samama Fahim
But Jakob Schwichtenberg in No-Nonsense Quantum Field Theory, p. 600 writes:
$$\partial_i\phi=\int d^3k \frac{1}{(2 \pi)^3 \sqrt{2\omega_k}} \left(a(\vec{k})(-ik_i)e^{-ikx}+a^{\dagger}(\vec{k})(ik_i)e^{ikx}\right).$$
Here $$kx \equiv k_{\mu}x^{\mu}$$
Apologies, Schwichtenberg's is correct (it's just due to the index placement on ##k##, which I'd overlooked). Remember that ##kx = k_{\mu} x^{\mu} = k_0 x^0 + k_i x^i = k^0 x^0 - k^i x^i##, so that ##\partial_i(kx) = k_i = - k^i##.
Likes Samama Fahim
Actually on p. 58, Schwichtenberg defines $$p_{\mu}p^{\mu}$$ to be $$p_0p_0-\vec{p} \cdot \vec{p}$$. And he also uses the metric signature $$(1,-1,-1,-1)$$ and not $$p_0p_0+\vec{p} \cdot \vec{p}$$
That's correct, yes. By ##\mathbf{k} \cdot \mathbf{x}## one means ##k^i x^i##.
Likes Samama Fahim
##\vec{k} \cdot \vec{x} = k_ix_i##, is that true also?
It would be, yes, simply because ##k^i x^i = (-k_i)(-x_i) = k_i x_i##.
But be careful to note that the symbol ##\partial_i \equiv \partial / \partial x^i## refers to differentiation w.r.t. ##x^i##, not ##x_i##.
It all works out, but you have to be careful not to trip up on signs anywhere!
Likes vanhees71 and Samama Fahim
Thank you so much for all the responses.
But on p. 311, Schwichtenberg writes $$kx \equiv k_0x_0-k_ix_i$$ and goes on to take the derivative $$\partial_0 e^{ik_0x_0} = ik_0 e^{ik_0x_0} $$
It's still fine, because ##k_0 = k^0## and ##x_0 = x^0##. When using (+---), i.e. when ##\eta_{00} = 1##, you can raise/lower a ##0## index without having to change the sign.
Likes Samama Fahim
Four-divergence is
$$\partial_{\mu}K^{\mu}=\partial_0K^0+\partial_iK^i.$$
However, on p. 160 Schwichtenberg writes
$$0=\partial_{\mu}T^{\mu}_0$$
$$=\partial_0T^0_0-\partial_iT^i_0.$$
Why the minus sign? Here T denotes momentum-energy tensor.
That does look like a blunder, though it doesn't change the argument much.\begin{align*}
\partial_{\mu} T^{\mu}_0 = \partial_0 T^0_0 + \partial_i T^i_0 &= 0 \\ \\
\implies \int_V d^3 x \partial_0 T^0_0 &= -\int_V d^3 x\partial_i T^i_0 \\
\implies \int_{V} d^3 x \partial_0 T^0_0 &= -\int_{\partial V} d^2 S_i T^i_0 = 0
\end{align*}so that ##\dfrac{d}{dx_0} \displaystyle{\int_{V} d^3 x T^0_0} = 0##.
Likes Samama Fahim
