Total ordered pair in factorial equation
In summary, there are a limited number of integer ordered pairs $(x,y)$ that satisfy the equations $x^2-y! = 2001$ and $x^2-y! = 2013$. In the first case, $x$ must be a multiple of $3$ and $y$ must be less than $6$, while in the second case, $x$ must also be a multiple of $3$ and $y$ must be less than $5$. This means that there are only a few possible solutions for each equation.
juantheron
247
(A) Total no. of integer ordered pairs $(x,y)$ in $x^2-y! = 2001$
(B) Total no. of integer ordered pairs $(x,y)$ in $x^2-y! = 2013$
My Trail :: (A) Given $x^2-y! = 2001 = 3 \times 23 \times 29 \Rightarrow x^2 -y! = \left(3\times 23 \times 29\right)$
means $(x^2-y!)$ must be divisible by $3$ So $x = 3k$ anf $y\geq 3$, where $k\in \mathbb{Z}$
So $9k^2-y! = 3\times 23 \times 29$
Now How can i solve after that
Thanks
Mathematics news on Phys.org
[sp]The smallest square greater than $2001$ is $45^2 = 2025 = 4! + 2001$. So that gives you one solution.
You have shown that $x$ is a multiple of $3$, and so $x^2$ is a multiple of $9$. But $2001$ is not a multiple of $9$. So if $x^2 - y! = 2001$ then $y!$ must not be a multiple of $9$. Therefore $y<6$. That severely limits the number of possible solutions!
For (B), $2013$ is also a multiple of $3$ but not a multiple of $9$. So you can apply a very similar argument in that case too.[/sp]
FAQ: Total ordered pair in factorial equation
What is a total ordered pair in a factorial equation?
A total ordered pair in a factorial equation is a set of two numbers written in a specific order, where the first number represents the value to be factorialized and the second number represents the number of times the factorial operation should be applied. For example, in the factorial equation 4!, the total ordered pair would be (4,1).
What is the significance of a total ordered pair in a factorial equation?
The total ordered pair in a factorial equation helps to determine the specific value of the factorial operation. It indicates the number to be factorialized and the number of times the operation should be applied, resulting in a unique value for each pair.
How is a total ordered pair written in a factorial equation?
A total ordered pair is typically written in parentheses with a comma separating the two numbers. For example, (3,2) would represent the equation 3!
Can a total ordered pair have negative numbers?
No, a total ordered pair in a factorial equation cannot have negative numbers. The value to be factorialized must be a positive integer and the number of times the operation should be applied must also be a positive integer.
How is a total ordered pair used in a factorial equation?
A total ordered pair is used in a factorial equation to determine the specific value of the factorial operation. The first number in the pair is the value to be factorialized, and the second number represents the number of times the operation should be applied. The result of the equation will be the factorial of the first number, applied the number of times specified by the second number.
