Total spin angular momentum meaning
In summary, the total orbital spin angular momentum is given by the formula L2=l(l+1), which is obtained by applying the angular momentum operator to the solutions of the Schrödinger equation for the hydrogen atom. This number represents the magnitude of the orbital angular momentum and its component along the z-direction is determined by the quantum number ml. Similarly, for the electron, the total spin angular momentum is given by S2=1/2(1/2+1)hbar2. This represents the magnitude of the spin angular momentum and its component along the z-direction is determined by the quantum number ms. The total angular momentum is the vector sum of the orbital and spin angular momenta, with its magnitude given by J2
galvin452
Two questions
1) The total orbital spin angular momentum is given as L2=l(l+1). What is the source of or meaning of the (l+1).
2) Similarly for the electron the total spin angular momentum is given as S2-1/2(1/2+1) hbar2. Is the total angular momentum precessing to give sz 1/2 hbar object?
galvin452 said:
Two questions
Or is it that the electron has two intrinsic spin values?
There's no such thing as "total orbital spin angular momentum."
Orbital angular momentum has magnitude ##L = \sqrt{l(l+1)} \hbar##, and its component along any direction (usually we use the z-direction) is ##L_z = m_l \hbar## where ##m_l = -l \cdots +l## in steps of 1.
Spin angular momentum has magnitude ##S = \sqrt{s(s+1)} \hbar##, and its component along any direction (usually we use the z-direction) is ##S_z = m_s \hbar## where ##m_s = -s \cdots +s## in steps of 1. For e.g. an electron, s = 1/2, so ms = -1/2 or +1/2.
Total angular momentum has magnitude ##J = \sqrt{j(j+1)} \hbar##, and its component along any direction (usually we use the z-direction) is ##J_z = m_j \hbar## where ##m_j = -j \cdots +j## in steps of 1.
(Some books use different notation.)
For orbital angular momentum, one way to get the ##l(l+1)## is to apply the (orbital) angular momentum operator to the solutions to the Schrödinger equation for e.g. the hydrogen atom. There's probably a "deeper" way to get it which applies to all three kinds of angular momentum, but someone else will have to provide it.
No that's pretty much it - in QM classes (here anyway) we force students to do that calculation.
The quantum number basically comes from counting the states. There are three dimensions and the surd comes from the vector sum. You actually have to crunch through the equations to see it.
One may expect that the lth L state would have L=l\hbar ... but that neglects stuff like that there are three dimensions. The x(x+1) pattern is kind-of a symmetry in angular momentum.
Related to Total spin angular momentum meaning
1. What is total spin angular momentum?
Total spin angular momentum refers to the total amount of spin possessed by a system, which includes both the orbital and intrinsic spin of all particles within the system. It is a fundamental aspect of quantum mechanics and is used to describe the spin state of particles.
2. How is total spin angular momentum measured?
Total spin angular momentum is measured using an operator called the total spin operator, which takes into account the spin of all particles within the system. This operator is applied to the wave function of the system to obtain the total spin value.
3. What is the significance of total spin angular momentum?
Total spin angular momentum is significant because it is a conserved quantity in many physical processes, such as particle interactions and nuclear reactions. It also plays a crucial role in determining the properties and behavior of particles, such as their magnetic moment and energy levels.
4. Can total spin angular momentum change?
Yes, total spin angular momentum can change in certain physical processes, such as particle decays or interactions. However, it is always conserved overall and cannot be created or destroyed.
5. How is total spin angular momentum related to other types of angular momentum?
Total spin angular momentum is related to other types of angular momentum, such as orbital angular momentum and intrinsic spin, through the total angular momentum operator. The total angular momentum of a system is the sum of these different types of angular momentum.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
