Totally ordered and Partially ordered Sets
  • Thread starter dpa
  • Tags
    Sets
In summary, partial orders allow for comparisons between elements that don't always follow the trichotomy law.
dpa
147
Hi Everyone,
What are the difference between totally and partially ordered sets?
Any examples would help except the fact that one holds reflexivity and another totality. Clarification of this would also be fine.
Thank You
Consider the set: {1, 2, 3, 4, 5, 6, 7, 8, 9, 10}. As you can see, there is a total order on this set defined by: a < b if a-b < 0. (This is just the regular ordering of integers.)
On the other hand, there is a partial order: a < b if and only if a divides b. So that, in this partial order, 5 < 10, as in the total order, but 5 is not less than 7 in this partial order.
Any "order relation" obeys the "transitive law": if a<b and b<c then a< c. A "total order" also obey the "trichotomy law": Given any a, b in the set, one and only one must be true- a< b, b< a, a= b. We can say that all member so the set are "comparable"- given any two distinct members, we can "compare" them, one is < the other.
The important thing for Robert1986's second example is not just that "5 is not less than 7" but also that "7 is not less than 5" while of course 5 is not equal to 7 so trichotomy does not hold.
A very important example of a partial order is "set inclusion". We define "A< B" if and only if A is a subset of B. Certainly, if A is a subset of B and B is a subset of C, then A is a subset of C. If, for example, our 'universal set' is the set of positive integers, A= {1, 2, 3} and B= {2, 3, 4}, A and B are certainly not equal but also neither is a subset of the other. None of "A= B", "A is a subset of B", or "B is a subset of A".
FAQ: Totally ordered and Partially ordered Sets
What is the difference between a totally ordered set and a partially ordered set?
A totally ordered set, also known as a linearly ordered set, is a set in which every element is comparable to every other element in terms of a certain ordering relation. This means that for any two elements in the set, one is always greater than or equal to the other. In contrast, a partially ordered set is a set in which not every element is comparable to every other element. This means that some elements can be equal, but not necessarily greater than or less than each other.
What is a maximum element in a totally ordered set?
A maximum element in a totally ordered set is an element that is greater than or equal to all other elements in the set. In other words, it is the largest element in the set. Not all totally ordered sets have a maximum element, and if they do, it is always unique.
Can a partially ordered set have more than one minimal element?
Yes, a partially ordered set can have more than one minimal element. A minimal element is an element that is less than or equal to all other elements in the set. In a partially ordered set, there can be multiple minimal elements that are not comparable to each other.
What is the difference between a well-ordered set and a totally ordered set?
A well-ordered set is a totally ordered set in which every non-empty subset has a least element. This means that there is a clear starting point for any subset of the set, making it easier to analyze and compare elements. In a totally ordered set, there may not be a clear starting point for every subset.
What is an example of a totally ordered set?
An example of a totally ordered set is the set of integers (Z). In this set, every element is comparable to every other element, and there is a clear ordering from least to greatest. Another example is the set of real numbers (R), where every element is also comparable and there is a clear ordering.
