TOUGH Static Equilibrium Question
In summary, the problem involves determining the tension in a horizontal cable and the vertical and horizontal components of the force exerted by a pivot on an aluminum pole with a traffic light attached. Using the equations of equilibrium and considering the moments about the pivot, the tension was found to be equal to the horizontal component of the force exerted by the pivot on the pole. The vertical component of the force was calculated to be 309 N, but the horizontal component, determined by dividing this value by the tangent of the angle, was found to be incorrect. Further calculations are needed to determine the correct value.
Hotsuma
41
A traffic light hangs from a pole as shown in the figure (Intro 1 figure, see link: http://session.masteringphysics.com/problemAsset/1058163/3/GIANCOLI.ch12.p21.jpg" ) . The uniform aluminum pole AB is 7.20 m long and has a mass of 11.0 kg. The mass of the traffic light is 20.5 kg.
Part 1) Determine the tension in the horizontal massless cable CD.
Part 2) Determine the vertical component of the force exerted by the pivot A on the aluminum pole.
Part 3) Determine the horizontal component of the force exerted by the pivot A on the aluminum pole.
[tex]\sum{}F=0[/tex]
[tex]\sum\tau=0[/tex]
One of those should be F, for some reason TeX is not working for me...
Okay, so first I calculate all the distances between the points:
CD = 5.72 m
AD = 6.868 m
DB = .332 m
The two theta values are:
37*
53*
From there I know the x components and y components of Force should be zero, and I find that the vertical component of force exerted by the pivot A is 309 N. This answer for Part 2 is correct. From then I tried to calculate the horizontal component by dividing that number by tangent of 37 degrees (or by multiplying by 53 degrees) but the answer, 410 N, is not correct. I know from the summation of forces on the x co-ordinate plane that the tension force should equal the horizontal component of force from the arm A, which is part 3. So part 1 = part 3. However, I don't know how to get any other information from this point, because summation of torques only can give me what I already know. Is this a problem with Mastering Physics and should I just double check my values?
For 1) you really just need to consider the Σ T about the pivot.
You have 3 forces. The weight of the light at a moment arm of 7.2m and the Center of mass of the pole at 3.6m Added together then they are both acting clockwise about the pivot at cos 37.
The 3rd force is your Tension acting counter clockwise at a distance given by the problem as 3.8m. That makes the answer then just the Σ of the clockwise T / 3.8m.
You should be able to determine the remaining components then of the forces acting along the pole into the pivot, now that you know the 3 forces acting on it.
Or am I missing something?I would approach this problem by first carefully reviewing the given information and making sure all the values and equations are correct. It is possible that there may be a mistake in the given values or in the equations used to solve the problem.
Next, I would use a systematic approach to solve the problem, making sure to clearly define the coordinate system and direction of forces. This will help to avoid any confusion and ensure that the calculations are accurate.
I would also double check the calculations and make sure all units are consistent throughout. Sometimes, a small mistake in units can lead to incorrect answers.
If all the calculations and values seem correct, I would then consider other factors that may be affecting the system, such as friction or air resistance. These forces may be small but can still have an impact on the equilibrium of the system.
If I am still unable to solve the problem, I would seek assistance from a colleague or consult additional resources to gain a better understanding of the concepts involved. As scientists, it is important to continuously learn and seek help when needed in order to solve complex problems.
Related to TOUGH Static Equilibrium Question
1. What is static equilibrium?
Static equilibrium refers to the state in which an object is at rest and the sum of all forces acting on it is equal to zero. This means that there is no net force or torque acting on the object, and it will remain in its current position unless an external force is applied.
2. How do you calculate the forces in a TOUGH static equilibrium question?
To calculate the forces in a TOUGH static equilibrium question, you must first draw a free body diagram of the object. This will help you identify all the forces acting on the object and their direction. Then, you can use the equations of static equilibrium, such as Newton's laws of motion and the sum of torques, to solve for the unknown forces.
3. What is the difference between TOUGH static equilibrium and regular static equilibrium?
TOUGH static equilibrium refers to the application of static equilibrium principles to more complex and challenging problems, often involving multiple forces and objects. Regular static equilibrium problems are usually simpler and involve only a few forces acting on a single object.
4. What are some common mistakes to avoid when solving a TOUGH static equilibrium question?
Some common mistakes to avoid when solving a TOUGH static equilibrium question include not considering all the forces acting on the object, using incorrect signs for forces, and not properly setting up the equations of static equilibrium. It is important to carefully analyze the problem and double-check your calculations to avoid these errors.
5. What real-world applications involve TOUGH static equilibrium?
TOUGH static equilibrium has many real-world applications, such as designing structures like bridges and buildings, analyzing the stability of objects on inclined planes, and understanding the forces acting on the human body in different positions. It is also used in fields like engineering, physics, and architecture to solve complex problems and optimize designs.
