Trace of momentum-space propagator
In summary, the integral:\int \Pi_k d\phi_k e^{-\phi_i A_{ij} \phi_j} is a Gaussian and is equal to:(\pi)^{n/2}\sqrt{det(A^{-1})}= (\pi)^{n/2} e^{\frac{1}{2}Tr ln A^{-1}}
RedX
970
The integral:
[tex]\int \Pi_k d\phi_k e^{-\phi_i A_{ij} \phi_j} [/tex]
[tex](\pi)^{n/2}\sqrt{det(A^{-1})}= (\pi)^{n/2} e^{\frac{1}{2}Tr ln A^{-1}}[/tex]
Now usually A is a diagonal matrix that represents the Lagrangian (so that the sum over i and j collapses to a sum just over i, and this sum is converted to an integral for continuum), and [tex]A^{-1}[/tex] would then be the propagator matrix.
The book I'm reading says that the trace of [tex]A^{-1} [/tex] is best evaluated in the momentum representation where it is diagonal. But how is [tex]A^{-1} [/tex] diagonal in this representation?
For example if you take this expression:
[tex]e^{\int \int dx dy j(x) A^{-1}(x,y) j(y)} [/tex]
but change to momentum space then you get something like:
[tex]e^{\int dk j(-k) A^{-1}(k) j(k)}=e^{\int \int dk dq j(q) A^{-1}(k) \delta(k+q) j(k)} [/tex]
Doesn't this suggest that [tex] A^{-1}[/tex] is not diagonal in momentum space? If it were diagonal, then there would be a [tex]\delta(k-q) [/tex] and not [tex]\delta(k+q) [/tex] on the RHS.
I'm pretty sure TrA (or Tr(lnA)) is not the same as [tex] \int \int dx dy j(x) A^{-1}(x,y) j(y)
[/tex] because this expression depend on j(x) you choose.
I think your book means usually A's eigenvectors are monochromatic waves, for example if A is the Klein-Gordon operator, then A's eigenvectors are expi(kx-wt) with eigenvalues
[tex]{\omega ^2} = {k^2} + {m^2}[/tex], then the trace is just the sum of all eigenvalues:
[tex]\begin{array}{l}
TrA = \int {dk(} {k^2} + {m^2}) \\
Tr\ln {A^{ - 1}} = \int {dk} \ln \frac{1}{{{k^2} + {m^2}}} \\
\end{array}[/tex]
A Fourier transform F is a type of linear transform, so if F diagonalizes a matrix A, then for any two vectors x and y:
[tex]x^TAy= x^T(F^{T}DF)y=(Fx)^TD(Fy)
[/tex]
for a diagonal matrix D.
So if you allow j(x) and j(y) to be your vectors x and y except in continuum, then for the Fourier transforms F[j(x)]=j(k), I think the continuum analog should be:
[tex]
e^{\int \int dx dy j(x) A^{-1}(x,y) j(y)}=e^{\int \int dk dq j(q) D(k,q) j(k)}
[/tex]
But D(k,q) is not diagonal since it has a delta(k+q) and not a delta(k-q).
I would like to make the claim that maybe j(k)=j(-k) if you require j(x) to be real, but that's not necessarily true.
Actually, [tex]j^{\dagger}(k)=j(-k) [/tex] is the most general condition, so maybe it ought to be:
[tex]
e^{\int \int dx dy j(x) A^{-1}(x,y) j(y)}=e^{\int \int dk dq j^{\dagger}(q) D(k,q) j(k)}= e^{\int \int dk dq j^{\dagger}(q) D(k)\delta(k+q) j(k)}
=e^{\int dk j^{\dagger}(-k) D(k) j(k)}=e^{\int dk j(k) D(k) j(k)}
=e^{\int \int dq dk j(q) D(k)\delta(k-q) j(k)}
[/tex]
since the Fourier transform that diagonalizes [tex]A^{-1}[/tex] should be unitary and not orthogonal, and hence the dagger on j is required.
I‘m not saying your math is wrong, but it''s just not Tr A, because Tr A should be a fixed value independent of j(x). And by "momentum representation" my understanding is to express A in terms of monochromatic plane waves, which are the eigen solutions of A, not simply change the integration measure to ,momentum space.
FAQ: Trace of momentum-space propagator
What is the trace of momentum-space propagator?
The trace of momentum-space propagator is a mathematical quantity used in quantum field theory to calculate the probability amplitude for a particle to travel from one point to another in spacetime. It is represented by the symbol "Tr" and is calculated by summing over all possible paths that the particle can take between the two points.
How is the trace of momentum-space propagator calculated?
The trace of momentum-space propagator is calculated using the Feynman path integral, which is a mathematical method for calculating quantum mechanical amplitudes. It involves summing over all possible paths that a particle can take between two points in spacetime and weighting them by a phase factor.
What is the significance of the trace of momentum-space propagator?
The trace of momentum-space propagator is an important quantity in quantum field theory as it allows us to calculate the probability amplitude for particles to travel between two points in spacetime. This is essential for understanding the behavior of particles at the quantum level.
How does the trace of momentum-space propagator relate to particle interactions?
The trace of momentum-space propagator is used to calculate the probability amplitude for particle interactions. It allows us to determine the likelihood of particles interacting with each other at a specific point in spacetime, which is crucial for understanding the behavior of particles in quantum field theory.
Can the trace of momentum-space propagator be experimentally measured?
No, the trace of momentum-space propagator is a mathematical quantity that cannot be directly measured in experiments. It is a theoretical concept used to calculate probabilities and amplitudes in quantum field theory. However, its predictions can be tested and verified through experimental results.
