Trace of the stress energy tensor
In summary, the stress energy tensor has many forms based on the type of matter you are describing, and the trace of these tensors is invariant under coordinate transformations. However, the traces of the stress-energy tensors for different types of matter will not all be the same. For example, the trace of the stress-energy tensor for electromagnetic radiation is zero, while the trace for dust and perfect fluid is nonzero but different from each other. Additionally, the perfect fluid with nonzero pressure has a trace that depends on the equation of state parameter, w.
dsaun777
296
39
The stress energy tensor has many forms based on the type of matter you are describing, dust, fluid, perfect fluid... is it true that the trace of all of these matter situations is invariant?
The trace of any tensor is invariant under coordinate transformations.
Likes Tertius and vanhees71
As @Nugatory said, the trace of any tensor is invariant under coordinate transformations. However, the traces of the stress-energy tensors describing different kinds of stress-energy will not all be the same. For example, the trace of the stress-energy tensor describing electromagnetic radiation is zero; but the trace of the stress-energy tensor describing dust is nonzero. And the trace of the stress-energy tensor describing a perfect fluid is also nonzero, but different from that of dust.
Likes vanhees71
Dust is a particular case of a perfect fluid with ##w=0##. A perfect fluid has the trace ##\rho(1+3w)## of the stress-energy tensor, which can a priori take any value unless one starts introducing additional requirements on the equation of state parameter ##w##.
And w being pressure/ density?
Yes, in the rest frame of the fluid.
Likes vanhees71
Yes, I should have been clearer, by "perfect fluid" I meant "perfect fluid with nonzero pressure", which would correspond to ##w \neq 0##.
Related to Trace of the stress energy tensor
What is the stress energy tensor?
The stress energy tensor is a mathematical object used in the field of physics to describe the distribution of energy and momentum in a given space. It is a rank-2 tensor that relates the energy and momentum of a system to its curvature and gravitational field.
Why is the stress energy tensor important?
The stress energy tensor is important because it is a fundamental concept in general relativity and is used to describe the behavior of matter and energy in the universe. It is also a key component in Einstein's field equations, which describe the relationship between matter and the curvature of spacetime.
How is the stress energy tensor calculated?
The stress energy tensor is calculated using the Einstein field equations, which involve the curvature of spacetime and the energy-momentum tensor. The energy-momentum tensor is calculated by summing the contributions of all the particles and fields in a given space.
What is the physical interpretation of the stress energy tensor?
The stress energy tensor has a physical interpretation as it represents the flow of energy and momentum in a given space. It also describes the distribution of matter and energy in the universe and how it affects the curvature of spacetime.
What are some applications of the stress energy tensor?
The stress energy tensor has various applications in the field of physics, including in cosmology, astrophysics, and high-energy physics. It is used to study the behavior of matter and energy in the universe, the formation of galaxies, and the dynamics of black holes and other astronomical objects.
