chrissyinoregon
- 2
When driving on snow and ice does engine braking (by downshifting) provide more traction than applying brakes in a slow and controlled manner?
Probably not.chrissyinoregon said:When driving on snow and ice does engine braking (by downshifting) provide more traction than applying brakes in a slow and controlled manner?
jfoldbar said:i don't know about the theories, but I am a 4wder, always taking my 4wd in bush. i can tell you from real like experience, engine braking is usually the best.
jfoldbar said:ie, if you are in the habit of trusting your foot brake over the engine brake, you are much more likely to roll your car.
An art becomes a science when it is rationalised and reduced to testable fundamentals. An art has no reasoning, code of practice or objective assesment. If it is not a science then there can be no discussion or understanding, only a subjective appreciation.JBA said:In reality, the only individuals that are even reasonably safe on ice and snow are those with experience under those conditions, it is definitely a learned art, not a science.
But jump in one of these and you will, at least, get a better understanding of the issue...[COLOR=#black].[/COLOR]JBA said:In reality, the only individuals that are even reasonably safe on ice and snow are those with experience under those conditions, it is definitely a learned art, not a science.
Mech_Engineer said:Engine braking cannot taking advantage of an ABS system if one of the wheel accidentally starts to slip. Careful, consistent pressure on the brake pedal is your best bet in ice and snow. Let the ABS system do its job.
To maintain traction while braking in snow and ice, it is important to apply gentle and consistent pressure to the brake pedal. Avoid sudden or hard braking, as this can cause your tires to lock up and lose traction. Additionally, make sure to keep a safe distance between yourself and other vehicles to allow for enough stopping distance.
Yes, your ABS should be used in snow and ice conditions. This system helps to prevent your tires from locking up and allows you to maintain steering control while braking. However, it is important to still apply gentle and consistent pressure to the brake pedal, as relying solely on your ABS can also cause your tires to lose traction.
Winter tires are specifically designed for cold and snowy conditions, and therefore, they provide better traction and braking performance in snow and ice compared to all-season tires. If you live in an area with frequent snow and ice, it is highly recommended to switch to winter tires during the winter months.
The best speed to drive at in snow and ice depends on the road conditions and your vehicle's capabilities. As a general rule, it is recommended to drive at a slower speed than normal and to increase the following distance between yourself and other vehicles. This allows you to have more time to react and brake safely if needed.
If your car starts to slide while braking in snow and ice, it is important to remain calm and avoid overreacting. Do not slam on the brakes or jerk the steering wheel, as this can make the slide worse. Instead, ease off the brake pedal and turn your steering wheel in the direction you want the car to go. If possible, try to steer towards an open and safe area until you regain control of the vehicle.
