Train collision problem, speed at impact
In summary, two trains, a red train traveling at 72 km/h and a green train traveling at 144 km/h, are headed towards each other on a straight, level track. When they are 950 m apart, the engineers see each other's trains and apply the brakes, which slow the trains at a rate of 1.0 m/s². Using the equation V² = Vo² + 2((delta)x), it can be determined that the trains will collide. To find their speeds at the instant of collision, equations for the distance each train travels after the brakes are applied can be set equal to each other, allowing for the time of collision to be solved for. Then, velocity formulas can be used to find
kazo0
1. A red train traveling at 72 km/h and a green train traveling at 144 km/h are headed toward each other along a straight, level track. When they are 950 m apart, each engineer sees the other’s train and applies the brakes. The brakes slow each train at the rate of 1.0 m/s2. Is there a collision? If so, answer yes and give the speed of the red train and the speed of the green train at impact, respectively. If not, answer no and give the separation between the trains when they stop.
I was able to find that the trains would indeed collide, I don't know how to find out the last part, what their speeds are at the instant that they collide. Can anyone help me out?
Thanks
i used the equation V^2 = Vo^2 + 2((delta)x)
Thanks
Write equations for the distance each train travels up to time t after the brakes are applied. By setting the total of the two distances to 950 m, you should be able to solve for the time of the collision. Then you can use velocity formulas for the two trains to find their speeds at that time.
To find the speeds of the trains at impact, we can use the equation for final velocity (V) in terms of initial velocity (Vo), acceleration (a), and displacement (Δx):
V^2 = Vo^2 + 2aΔx
For the red train, we have Vo = 72 km/h, a = -1.0 m/s^2 (since the brakes are slowing the train down), and Δx = 950 m. Converting the units to meters and seconds, we get:
V^2 = (20 m/s)^2 + 2(-1.0 m/s^2)(950 m)
V^2 = 400 m^2/s^2 - 1900 m^2/s^2
V^2 = -1500 m^2/s^2
Taking the square root of both sides, we get the speed of the red train at impact:
V = -38.7 m/s = -139.3 km/h (since the speed is negative, this means the train is moving in the opposite direction)
For the green train, we have Vo = 144 km/h, a = -1.0 m/s^2, and Δx = 950 m. Converting the units, we get:
V^2 = (40 m/s)^2 + 2(-1.0 m/s^2)(950 m)
V^2 = 1600 m^2/s^2 - 1900 m^2/s^2
V^2 = -300 m^2/s^2
Taking the square root, we get the speed of the green train at impact:
V = -17.3 m/s = -62.3 km/h (again, the negative sign indicates the train is moving in the opposite direction)
Therefore, the speeds of the trains at impact are -139.3 km/h for the red train and -62.3 km/h for the green train. This means that the red train was traveling faster than the green train before the collision, but they both slowed down due to the brakes and ended up colliding at a slower speed.
FAQ: Train collision problem, speed at impact
What is a train collision problem?
A train collision problem is when two or more trains collide with each other, resulting in damage to the trains and possibly injuries or fatalities to passengers and crew.
How is the speed at impact calculated in a train collision?
The speed at impact in a train collision is calculated by taking into account the initial velocities of the trains, the mass of the trains, and the angle of impact. This calculation is typically done using the principles of conservation of momentum and energy.
What factors can contribute to a train collision problem?
There are several factors that can contribute to a train collision problem, including human error, equipment failure, track defects, and weather conditions. Other factors such as inadequate training and lack of communication can also play a role.
How can train collisions be prevented?
Train collisions can be prevented through various measures such as implementing strict safety protocols, regular maintenance of equipment and tracks, and proper training for train operators. The use of advanced technology such as collision avoidance systems can also help prevent train collisions.
What are the potential consequences of a train collision?
The consequences of a train collision can be severe, including damage to property, injuries or fatalities to passengers and crew, and disruption of train services. It can also have significant economic impacts, such as delays and the cost of repairs and legal proceedings.
