Trajectory of a ball thrown vertically
In summary, a student throws a ball straight up from a height of 1.50 m with a speed of 11.0 m/s. The ball is in the air until it hits the ground and the student moves her hand out of the way. The problem involves finding the time the ball is in the air before hitting the ground. The student is unsure of how to approach the problem, but it involves understanding the relationship between height and time for an object under the influence of gravity.
bommer
A student standing on the ground throws a ball straight up. The ball leaves the student's hand with a speed of 11.0 m/s when the hand is 1.50 m above the ground.
How long is the ball in the air before it hits the ground? (The student moves her hand out of the way.)
Describe what you have done so far to solve the problem.
sorry this is bommer. had to change my s/n
i don't know where to start on this problem
What do you know about the relationship between height and time for an object moving under the influence of gravity?
FAQ: Trajectory of a ball thrown vertically
1. What is the trajectory of a ball thrown vertically?
The trajectory of a ball thrown vertically can be described as a parabola. This means that the ball will follow a curved path, reaching a maximum height before falling back down to the ground.
2. How high will the ball go when thrown vertically?
The height that the ball will reach when thrown vertically depends on the initial velocity and the force of gravity. However, it will always reach a maximum height before falling back down to the ground.
3. How does air resistance affect the trajectory of a ball thrown vertically?
Air resistance can affect the trajectory of a ball thrown vertically by slowing down the ball and causing it to reach a lower maximum height. This is because air resistance creates a force that opposes the motion of the ball, causing it to lose momentum.
4. Does the mass of the ball affect its trajectory when thrown vertically?
The mass of the ball does not significantly affect its trajectory when thrown vertically. This is because the force of gravity acts on all objects equally, regardless of their mass. However, a heavier ball may be more resistant to air resistance, causing it to reach a higher maximum height.
5. How does the angle at which the ball is thrown affect its trajectory?
The angle at which the ball is thrown can greatly affect its trajectory. When thrown at a shallow angle, the ball will travel a longer horizontal distance before reaching its maximum height and falling back to the ground. When thrown at a steeper angle, the ball will reach a higher maximum height but will also have a shorter horizontal distance.
