Trajectory of an airdropped bomb
In summary: If you use a rigid rod (or a stiff cable), the aircraft will tumble. I suspect any competition will have rules to limit the length of the tether, and that will probably be the easiest way to deal with it.In summary, the problem at hand is to derive an equation for the place where an airdropped bomb will hit the ground. The known data at the moment of drop includes the position [x,y,z], pitch angle, linear and angular velocities, accelerations of the plane, velocity of wind, mass of the bomb, drag coefficient, and g and air density. The angular velocities of the airplane only cause additional acceleration of the bomb, and can be neglected for the point where the bomb is dropped. The main
LilFly
I want to derive an equation for the place where airdropped bomb is going to hit the ground.
Known data at the moment of drop:
1) position [x,y,z] also and the pitch angle (between the airplane's axis and the ground - we assume that Earth is flat)
2) linear and angular velocities [vx,vy,vz] and xyz]
3) accelerations of the plane [ax,ay,az]
4) velocity of wind [wx,wy,wz]
5) mass of the bomb m
6) drag coefficient of the bomb Cd which we assume to be constant in all directions
7) g and the air density ρ
Angular velocities cause only additional acceleration of the bomb (as the bomb is attached at some distance from the center of gravity of and aircraft)
Drag: D=Cd*S/2*ρ*v2, S is also given
I am pretty sure that what I have to do is to write equations of motion.
First of all I find the net velocity -> sum of the linear velocity and wind velocity.
However what is my problem is how to deal with this additional acceleration caused by the angular velocity? And should I take anything else into consideration?
For example I would start it for z axis as follows
[itex]mz'' = -Q - D_z + ma_z+...[/itex] is this correct and if yes what to do with angular velocities?
Please, do help me :)
As long as it is attached to the airplane, the airplane will set its velocity. Afterwards, the airplane does not matter any more. For the point where the bomb gets dropped: yeah, in principle a rotation of the plane would influence the velocity a bit, but I think you can neglect this. Approximation (6) is much worse I guess. Therefore, linear velocities should be fine.
I am also taking care of the 6th approximation, I've given it just not to mess up the picture. Let say bomb is not stiffly attached but has some freedom of movement then how can I include this? (Angular velocities cause only additional acceleration of the bomb (as the bomb is attached at some distance from the center of gravity of and aircraft))
Some freedom of movement relative to the airplane, while still attached? Then you'll need a mechanical model of this attachment mechanism.
What is the scope of this problem? Assuming you don't want to drop actual bombs, why do you care about those details?
I am designing an UAV (for competition) which has to drop a package near the given location. I haven't decided yet on how to attach the 'bomb' however I know that it is going to be some kind of a 'hook' so it's not going to be stiff and since at the moment of drop aircraft is going to have big angular velocity I want to include it in my mathematical model. At this point we can introduce some kind of a constant which simulates the hook and the distance from the center of gravity and still I want to somehow include this in equations of motions and I don't know how
Ah, well. It all boils down to finding the current position and velocity of the package at release time, nothing else matters. How exactly this is determined will depend on the aircraft and hook design.
Ok. Even if the 'bomb' is stiffly attached to the airplane but the airplane has the angular velocity (and since the bomb is not attached in the centre of gravity), the bomb will gain extra acceleration due to centrifugal force. And I just want to know how to deal with it, given the distance from the bomb's and airplane's centres of gravity.
I suspect MFN is right and the assumptions in drag coefficient and it's impact on the final position is probably dominant over issues of initial angular momentum
As I said, I am taking care of drag on my own. And I am not asking about how big the impact is going to be (but as the angular velocity is going to be big the effect will be noticeable), but how to include it in equations of motion if I know it's position in comparison to the airplane's center of gravity.
Not so. As has been posted, all that matters are the velocity and position of the bomb at the instant of release. The radial acceleration of the aircraft (i.e. the curved nature of its path) only comes into it as part of calculating that velocity. The 'angular acceleration' of the aircraft doesn't seem to come into it at all.
Going back to the original problem, a rigid tether of any length will seriously affect the movement of the aircraft, and may be hard to achieve. For a cable, you'd need to compute the shape of the cable induced by the drag on that.
FAQ: Trajectory of an airdropped bomb
1. What factors affect the trajectory of an airdropped bomb?
The trajectory of an airdropped bomb is affected by several factors including the initial velocity, wind speed and direction, air resistance, and gravity. The shape and weight distribution of the bomb also play a role in determining its trajectory.
2. How does air resistance impact the trajectory of an airdropped bomb?
Air resistance, also known as drag, can significantly affect the trajectory of an airdropped bomb. As the bomb travels through the air, it experiences drag force which opposes its motion and can cause it to slow down and change direction. The shape and size of the bomb can impact the amount of drag force it experiences.
3. Can the trajectory of an airdropped bomb be predicted accurately?
While there are various factors that can affect the trajectory of an airdropped bomb, it can be predicted with a high level of accuracy using mathematical models and simulations. These models take into account various variables such as initial conditions and environmental factors to predict the trajectory of the bomb.
4. How does gravity influence the trajectory of an airdropped bomb?
Gravity plays a crucial role in determining the trajectory of an airdropped bomb. As the bomb falls towards the ground, it experiences a constant acceleration due to gravity which pulls it downwards. This acceleration affects the speed and direction of the bomb, ultimately determining its trajectory.
5. Can the trajectory of an airdropped bomb be controlled?
The trajectory of an airdropped bomb can be influenced to a certain extent by controlling the initial velocity and direction of the bomb, as well as altering its shape and weight distribution. However, factors such as wind and air resistance can make it difficult to fully control the trajectory of the bomb. Precision-guided bombs, equipped with technology such as GPS, are designed to have a more precise trajectory and can be controlled to a greater degree.
