Transfer data from memory to register / register to memory?
In summary: Opcode instruction mode example000000 nop 0 address ------000001 Load 1 number
vead
92
hello
I need some help. I created one example to understand some basic
component
ram memory
A accumulator 4bit
R1 resistor 4 bit ( R1 is temporary data storage register )
  • Register memory address bus - 2 bits (RA0,1);
  • Register memory data bus - 4 bits (RD0~3);
  • Register memory read enable;
  • Register memory write enable.
Load the data directly with register R1
mov R1 # data
stored the content R1 register into register memory
Q1 how to write data (stored in R1) to register memory ?
load the data from memory register and store into A accumulator
Q2 how to read the content of R1 and stored into A register ?
Technology news on Phys.org
vead said:
hello
component
ram memory
A accumulator 4bit
mov R1 # data
A register already is memory, so there's no difference between writing directly to, say, register R1 and writing to register memory.
Since you are designing the instruction set for this hypothetical microprocessor, you should already have an instruction to do this. Something like mov A, R1. That will read the value in R1 and write it to the accumulator (A).
Likes vead
suppose we have 8 bit instruction
first 4 bit for opcode and last 4 bit for register specification I have following component component
ram memory
A accumulator 4bit
4 bit opcode +2 bit source register +2 bit destination register + 2 bit data
MOV A #data
mov R1 # data
how does A register or R1 know that Its a source register or destination register ?
first 4 bit for opcode and last 4 bit for register specificationI have following component component
ram memory
A accumulator 4bit
MOV A #data
mov R1 # data
A register doesn't "know" anything. It's the mov instruction that determines which register is read from (the source) and which register is written to (the destination).
look at my another effort
Instruction set
  • opcode - instruction name
  • operand - data or address
6 bit opcode +mode +5 bit source register + 6 bit for destination register
Mode
0 address (without #)
1 number (with #)
Code:
000001          Load                1 number                       Ld A # 12
000010          Load                0 address                       Ld 12
000100          Add                  0 address                       Add 12
001000          Add                  1 number                        Add A # 12
010000          Sub                  0 address                       Sub 12
100000          Sub                  1 number                        Sub A # 12
111111          Store               0 address                         ST 12
I wrote few instruction just for example .I have 256 instruction
Assembly code
loads the number 12 into the accumulator
Code:
Ld A # 12
Bianry code
000001 1 00000 001100
Assembly code
Code:
Add # 12
Add the number 12 into the accumulator
binary code
001000 1 00000 001100
stores the result into memory location 12
Code:
ST 12
Memory
address number
11 10
12 24
13 05
saves the accumulator result (24) to the memory address 12
Bianry code
001000 0 00000 001100
Assembly code
Ld A # 12
Add A # 12
ST 12
Code:
binary code
Ld A #5
Ld R1#3
Add A,R1
look this example here I am using source and destination register
my main problem that I don't understand how to specify the operand ?
If I have accumulator , memory register R1,R2 R3.....etc
Q1 how to know that which register use as source register or destination register . ?
because both accumulator and memory register can be used as source or destination
Q2how to make binary sequence for instruction set ( opcode source and destination register ) ?
I already made some sequence but I am getting problem when I try to make binary sequence for following example
Add A,R1
Instruction set
Mode
1 number (with #)
Code:
Assembly code
Code:
Ld A # 12
Bianry code
Assembly code
Code:
Add # 12
binary code
Code:
ST 12
Memory
address number
11 10
12 24
13 05
Bianry code
Assembly code
Ld A # 12
Add A # 12
ST 12
Code:
binary code
Ld A #5
Ld R1#3
Add A,R1
Do it the same way as you did the examples just before this (i.e., Ld A #12, Add A, #12, ST 12).
You're already specifying the operand in your binary code. For example, taking one of your examples above, you have
Taking these in groups from left to right, we have:
000001 - Load
1 - number
00000 - accumulator
001100 - immediate value 12
Add A,R1
I don't understand why this is so difficult for you. You have already specified how the bits in the binary code mean.
Related to Transfer data from memory to register / register to memory?
1. How do you transfer data from memory to a register?
The process of transferring data from memory to a register involves two steps: first, the address of the data in memory is loaded into the memory address register (MAR). Then, the actual data is transferred from the memory location specified by the MAR into the memory data register (MDR). This data can then be moved into the desired register for use.
2. What is the purpose of transferring data from memory to a register?
The purpose of this transfer is to make the data more easily accessible for the processor. Registers are much faster to access than memory, so by transferring frequently used data into registers, the processor can retrieve and use the data more quickly.
3. How is data transferred from a register to memory?
The process of transferring data from a register to memory is similar to the reverse process. The data is first loaded into the memory data register (MDR), and then the address of the memory location is loaded into the memory address register (MAR). The data is then written into the specified memory location.
4. Can data be transferred directly between two registers?
Yes, data can be transferred directly between two registers using a move instruction. This is often used for data manipulation or for transferring data between different parts of a program.
5. What are some common challenges in transferring data between memory and registers?
One common challenge is managing the limited number of registers available in a processor. This can require careful planning to ensure that all necessary data is transferred and stored in the available registers. Another challenge is ensuring that the data is transferred accurately and without any errors, as errors can lead to incorrect data being used by the processor.
  • Sticky
