Transformation law of the energy momentum tensor
In summary: of course, the basis vectors for the new coordinates won't all have unit length, but that's not a problem in and of itself.
filip97
31
We have 4-tensor of second rank. For example energy-momentum tensor ##T_μν##
, which is symmetric and traceless. Then
##T_{μν}=x_μx_ν+x_νx_μ##
where ##x_μ##
is 4-vector. Every 4- vector transform under Lorentz transform as (12,12). If we act on ## T_{μν}##
, by representation( with homomorphism) then we have
##D(T_{μν})=(D(x_μ)D(x_ν))+(D(x_ν)D(x_μ))##
,or
Tμν
transform as
##(\cfrac{1}{2},\cfrac{1}{2})⊕(\cfrac{1}{2},\cfrac{1}{2})=(1⊕0)⊕(1⊕0)=1⊕1⊕0⊕0##
But we have trace of two components ##0##
. On wikipedia write that traceless symmetric tensors transform on representation ##(1,1)=2⊕0##
Where is error?
Let's start with vectors (which don't transform at all, because they are invariant objects). The contravariant vector components transform with a Lorentz matrix ##{\Lambda^{\mu}}_{\nu}## according to
$$\bar{V}^{\mu}={\Lambda^{\mu}}_{\nu} V^{\nu}.$$
In terms of the usual naming of representations that's the transformation under ##(1/2,1/2)##. The covariant components accordingly transform as
$$\bar{V}_{\mu}={\Lambda_{\mu}}^{\nu} V_{\nu}.$$
Indices are raised and lowered with the Minkowski pseudo-metric components, ##(\eta_{\mu \nu})=(\eta^{\mu \nu})=\mathrm{diag}(1,-1,-1,-1)##. Further a Lorentz matrix obeys
$$\eta_{\mu \nu} {\Lambda^{\mu}}_{\rho} {\Lambda^{\nu}}_{\sigma}=\eta_{\rho \sigma}.$$
From this it follows that 2nd-rank tensor components transform as
$$\bar{T}^{\mu \nu} = {\Lambda^{\mu}}_{\rho} {\Lambda^{\nu}}_{\sigma} T^{\rho \sigma},$$
i.e. under ##(1/2,1/2) \otimes (1/2,1/2)## as it must be.
It's clear that you can decompose any 2nd-rank tensor in a symmetric traceless part, an antisymmetric, and the trace part. Start with the symmetric and antisymmstric decomposition:
$$T^{\mu \nu}=\frac{1}{2} (T^{\mu \nu}+T^{\nu \mu}) + \frac{1}{2} (T^{\mu \nu}-T^{\nu \mu})=S^{\mu \nu} + A^{\mu \nu}.$$
The symmetric part can be decomposed in a traceless and a trace part,
$$S^{\mu \nu} = S^{\mu \nu}-\frac{1}{4} \eta_{\rho \sigma} S^{\rho \sigma} \eta^{\mu \nu} +\frac{1}{4} \eta_{\rho \sigma} S^{\rho \sigma} \eta^{\mu \nu}.$$
It's clear that the trace-part components are invariant themselves, i.e., they are scalars.
Likes Dale
Ok, this is partialy cleared.
##(1/2,1/2)⊗(1/2,1/2)=1/2⊗1/2⊗1/2⊗1/2=(1\oplus 0)⊗(1\oplus 0)=##
##=(1⊗1)\oplus(0\otimes 0)=2\oplus 0\oplus0##, and on Wikipedia write that
traceless symmetric second rank tensor transformed as ##(1,1)=2\oplus 0\neq 2\oplus 0\oplus0##. We have traces in both (in first representation we have two times ##0## component, and in second once).
filip97 said:
For example energy-momentum tensor ##T_{μν}##
The stress-energy tensor is symmetric, but it is not always traceless.
filip97 said:
Then
where ##x_μ## is 4-vector.
This is not true in general either.
As others have pointed out, the symmetric stress energy tensor is not necessarily trace free. For example, an idealized pressureless fluid has a stress-energy tensor of
$$\begin{bmatrix} \rho & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \\ 0 & 0 & 0 & 0 \end{bmatrix}$$
which is obviously not trace free.
Like any other symmetric rank 2 tensor, the stress-energy tensor is diagonalizeable, though. See for instance wiki,
In analogy with the theory of symmetric matrices, a (real) symmetric tensor of order 2 can be "diagonalized".
Thus a coordinate transformation can put the tensor in the form.
$$\begin{bmatrix} \rho & 0 & 0 & 0 \\ 0 & P_x & 0 & 0 \\ 0 & 0 & P_y & 0 \\ 0 & 0 & 0 & P_z \end{bmatrix}$$
While you could further decompose it into a trace-free part, and the trace multipled by an identity matrix, the physical interpretation is easiest without decomposing it , in my opinion.
A general coordinate transformation could even make the stress-energy tensor diag(-1,1,1,1) at a point, but basis vectors wouldn't be of unit length in this case, which complicates the physical interpretation.
Likes vanhees71
I don't think this is true, at least not for the covariant form ##T_{\mu \nu}##. A general coordinate transformation can make the metric tensor ##g_{\mu \nu}## diag(-1, 1, 1, 1) at a point, but the metric tensor is not the same as the stress-energy tensor.
For the mixed form ##T^\mu{}_\nu##, yes, you can, by picking weird units for the coordinates, make the tensor diag(-1, 1, 1, 1) at a point (at least, you can if the pressures are nonzero to begin with), because raising an index changes the sign of the 0-0 component.
Hmmm - well, there's the obvious counterexample of diag(0,0,0,0) for empty space, now that I think about it. And even diga(##\rho##, 0, 0.0) which I already gave as an example, fails. So - yeah, ignore the bit about diag(-1,1,1,1) but keep the part about being able to diagonalize a rank 2 symmetric tensor.
What I should have said was that you can make non-zero terms in the diagonalization have unit magnitude by an appropriate coordinate transformations if you allow non-unit length basis vectors.
Another remark: The energy-momentum tensor of any relativistic field theory is traceless iff the theory is invariant under scaling transformations. Of course that's the case for the free electromagnetic field.
One should note that this is a very "fragile" symmetry. Already quantizing the free electromagnetic field breaks it, which phenomenon is dubbed "trace anomaly". Its generalization to non-Abelian gauge theories, particularly QCD, gives rise to almost all of the mass of the matter surrounding us, but that's another story.
Likes JD_PM, dextercioby and weirdoguy
filip97 said:
[tex](\cfrac{1}{2},\cfrac{1}{2})⊕(\cfrac{1}{2},\cfrac{1}{2})=(1⊕0)⊕(1⊕0)=1⊕1⊕0⊕0[/tex]
What does this mean? And where did get it from? I am surprised by the fact that nobody asked you these questions.
Your tensor product has the following UNIQUE Clebsch-Gordan decomposition [tex]\left( \frac{1}{2} , \frac{1}{2}\right) \otimes \left( \frac{1}{2} , \frac{1}{2}\right) = \left( 1 , 1 \right) \oplus \big\{ \left( 0 , 1 \right) \oplus \left( 1 , 0 \right)\big\} \oplus \left( 0 , 0 \right) .[/tex] In tensor language (as Vanhees71 explained to you) that corresponds to decomposing a general tensor [itex]T_{\mu\nu}[/itex] into irreducible tensors (i.e., tensors that don’t mix with each other under Lorentz transformations): [tex]T_{\mu\nu} = \left( \frac{1}{2} \left( T_{\mu\nu} + T_{\nu\mu} \right) - \frac{1}{4}\eta_{\mu\nu}T \right) + \frac{1}{2} \left( T_{\mu\nu} - T_{\nu\mu}\right) + \frac{1}{4}\eta_{\mu\nu}T ,[/tex] where [itex]T = \eta^{\mu\nu}T_{\mu\nu} \in (0,0)[/itex] is the scalar trace, [itex]\left( \frac{1}{2} \left( T_{\mu\nu} + T_{\nu\mu} \right) - \frac{1}{4}\eta_{\mu\nu}T \right) \in (1 , 1)[/itex] is the symmetric traceless part and [itex]\frac{1}{2} \left( T_{\mu\nu} - T_{\nu\mu}\right) \in \big\{ (0 , 1) \oplus (1 , 0)\big\}[/itex] is the antisymmetric part.
As for the energy-momentum tensor, in general it is neither symmetric nor traceless. In a Poincare symmetric theory, the energy-momentum tensor can be made symmetric. And, in order to make it symmetric and traceless, the theory must be invariant under a larger space-time symmetry group called the Conformal group.
Likes JD_PM, dextercioby, vanhees71 and 1 other person
Related to Transformation law of the energy momentum tensor
1. What is the transformation law of the energy momentum tensor?
The transformation law of the energy momentum tensor is a mathematical equation that describes how the components of the energy momentum tensor change when coordinates are transformed from one reference frame to another. It is an important concept in physics, particularly in the theory of relativity.
2. Why is the transformation law of the energy momentum tensor important?
The transformation law of the energy momentum tensor is important because it allows us to understand how energy and momentum are conserved in different reference frames. It also helps us to make accurate predictions about the behavior of physical systems in different frames of reference.
3. How does the transformation law of the energy momentum tensor relate to the conservation of energy and momentum?
The transformation law of the energy momentum tensor is directly related to the conservation of energy and momentum. This is because the components of the energy momentum tensor represent the energy and momentum of a physical system, and the transformation law ensures that these quantities are conserved in all reference frames.
4. Can the transformation law of the energy momentum tensor be applied to all physical systems?
Yes, the transformation law of the energy momentum tensor can be applied to all physical systems, as long as they are described by the laws of relativity. This includes both classical and quantum systems.
5. How is the transformation law of the energy momentum tensor derived?
The transformation law of the energy momentum tensor is derived from the principles of special relativity, which state that the laws of physics should be the same in all inertial reference frames. By applying these principles to the equations that describe energy and momentum, we can derive the transformation law of the energy momentum tensor.
