Transformation of Random Variables
In summary: It's because in calculus, we are thinking about functions that are everywhere continuous. In statistics, we are thinking about discrete random variables.
jimbobian
52
Ok, so I have this written in my notes and while going over it I have a few questions:
Suppose cubical boxes are made so that the length, X (in cm) of an edge is distributed as
[tex]
f(x)=\frac{1}{2}
[/tex]
for 9≤X≤11
0 otherwise
What sort of distribution will the volume, Y, of the boxes have, Y in cm^3.
So in my notes it says to do this:
FY(y) = P(Y≤y) = P(X3≤y)=P(X≤y1/3)=FX(y1/3)
But why is it not possible to go straight from the PDF of X to the PDF of Y, using the same technique of substituting X3 for Y like so:
fY(y) = P(Y=y) = P(X3=y)=P(X=y1/3 )=fX(y1/3)
Have put this here, because it isn't a homework question, more a general question that I've come across while revising but by all means move it if you disagree!
Pressed submit by accident, haven't finished writing the OP!
Edit: Finished now!
jimbobian said:
But why is it not possible to go straight from the PDF of X to the PDF of Y, using the same technique of substituting X3 for Y !
This is good question and an important one. (You see that the two methods produce different answers, right?)
The PDF of a discrete random variable X can be interpreted as the "the probability that ...", but it is technically incorrect to interpret it this was for a continuous distribution. [itex] f_X(x) [/itex] is not [itex] P(X = x) [/itex]. Often you can get away with thinking of continuous PDF's the wrong way and still get the right formulas. It's rather like how people think of [itex] \frac{dy}{dx} [/itex] as the ratio of two finite numbers and this helps them remember formulas in calculus. Thinking the wrong way is often helpful but it has pitfalls.A better way to think is that [itex] f_X(x) [/itex] is a function that is one factor in an expression that approximates the probability for [itex] X [/itex] being in an interval. For example, [itex] P(x - dx \le X \le x + dx) \approx f_X(x) 2 dx [/itex], thinking of [itex] dx [/itex] as a finite length.
If we approach this problem by reasoning with PDFs, we must use intervals and things don't look simple.
[tex] P( y - dy \le Y \le y + dy) = P( y - dy \le X^3 \le y+ dy) [/tex]
[tex]= P( (y-dy)^\frac{1}{3} \le X \le (y+dy)^\frac{1}{3}) [/tex]
[tex] = \int_{(y-dy)^\frac{1}{3}}^{(y+dy)^\frac{1}{3}} f_X(x) dx [/tex]
[tex] = \bigg|_{(y-dy)^\frac{1}{3}}^{(y+dy)^\frac{1}{3}} (\frac{1}{2} x) [/tex]
Perhaps we can do more manipulations with the dy's and dx's to get to the right answer. At least this suggests that, plugging-in [itex] x= y^\frac{1}{3} [/itex] into [itex] f_X( x) [/itex] isn't likely to work.
The question is related to a question from calculus: When we make the substitution x = g(y) in an integration, why can't we just change dx to dy? Why does the substitution involve a g'(y) ?
FAQ: Transformation of Random Variables
1. What is the definition of transformation of random variables?
Transformation of random variables refers to the process of converting a random variable with one probability distribution into another random variable with a different probability distribution.
2. Why do we use transformation of random variables?
Transformation of random variables allows us to simplify complex probability calculations and make them more manageable. It also helps in understanding the relationship between different variables and their distributions.
3. What are some common transformations used in statistics?
Some common transformations used in statistics include logarithmic, square root, and exponential transformations. Other transformations include inverse, power, and standardization transformations.
4. How does transformation affect the shape of a distribution?
The shape of a distribution can be affected by transformation. For example, a logarithmic transformation can make a skewed distribution more symmetric, while an exponential transformation can make a symmetric distribution more skewed.
5. What are the assumptions for using transformation of random variables?
The assumptions for using transformation of random variables include the random variable being continuous, the transformation being one-to-one and invertible, and the transformation function being continuous and differentiable.
