Transformation of the adjoint representation
In summary, the given equation shows that under the SU(2) subgroup of SU(N), the fundamental representation N transforms as 2 \oplus (N-2). This means that if a generator of the fundamental representation is denoted as T^a, it transforms as T^a \rightarrow \sigma \, \lambda \, T^a, where sigma is a SU(2) transformation matrix and lambda is a SU(N-2) transformation matrix. To find out how the adjoint representation transforms under this SU(2) subgroup, one would need to analyze the transformations of its generators.
ansgar
516
given that
[tex]N\otimes\bar{N} = 1 \oplus A [/tex]
consinder the SU(2) subgroup of SU(N), that acts on the two first components of the fundamental representation N of SU(N). Under this SU(2) subgroup, the repsentation N of SU(N) transforms as [itex] 2 \oplus (N-2) [/itex]
with info above, how does the adjoint representation transform under this SU(2) subgroup?
what does it mean that the representation transforms?
does it mean if I take one generator of the fundamental representation call it [tex] T^a [/tex]
that it transfors as [tex] T^a \rightarrow \sigma \, \lambda \, T^a [/tex]
where sigma is a SU(2) transformation matrix and lambda a SU(N-2) transf. matrix?
if this is the case, then how can I find out how the adjoint representation transform under this SU(2) subgroup?
Related to Transformation of the adjoint representation
1. What is the adjoint representation?
The adjoint representation is a mathematical concept used in the study of group theory. It is a mapping that associates each element of a group with a specific linear transformation on the group's representation space.
2. What does it mean to transform the adjoint representation?
Transforming the adjoint representation refers to changing the basis of the representation space, while keeping the group elements and their corresponding transformations the same. This allows for a different perspective or understanding of the group's properties.
3. Why is the transformation of the adjoint representation important?
The transformation of the adjoint representation can reveal hidden symmetries or relationships within a group, which can be useful in understanding the group's structure and applications in physics and other fields of science.
4. How is the transformation of the adjoint representation performed?
The transformation of the adjoint representation is performed by using a change of basis matrix to convert the original basis vectors to the new basis vectors. This results in new coefficients for the group's elements, but the group structure and transformations remain unchanged.
5. What are some applications of the transformation of the adjoint representation?
The transformation of the adjoint representation has applications in a wide range of fields, including physics, chemistry, and engineering. It is used to study symmetries and conservation laws in physical systems, as well as to understand the properties of molecules and crystals. It also has applications in signal processing and data analysis.
  • Differential Geometry
  • Linear and Abstract Algebra
