Transformer frequency contradiction on induction heating
Increasing transformer frequency can enhance efficiency in induction heating, but it also raises losses due to hysteresis and eddy currents. The equations governing these losses assume constant maximum flux density (Bmax), which does not hold true as frequency increases. In fact, Bmax decreases with higher frequencies, complicating the relationship between efficiency and losses. The skin effect plays a crucial role, as it causes current to concentrate near the conductor's surface, increasing resistance at higher frequencies. This counterintuitive behavior highlights the complexity of induction heating dynamics.
abdulbadii
TL;DR Summary
Help solve tangled transformer freq contradiction over induction heating
As a transformer freq bet higher, inside induction get more efficient i.e. less loss:
1. Hysteresis loss = η * Bmax^n * f * V.
2. Eddy current loss( proportional to B2mf2Bm2f2 )Now it seems that losses increases with increase in efficiency...
But the above equations are valid when max flux density Bmax remains constant.
The gist is that when increasing the frequency flux density does not remain constant, it actually decreases with increase in frequency, as
V = 4.44 . Bmax . A . f . Tp
Now how is it on Induction_heating, as it's read more, the more contradiction is to above
Yeah, seems counter intuitive doesn't it?
But it sounds like the Skin Effect is the important missing element here.
For DC and a solid conductor, current flow is evenly distributed throughout the cross section.
For AC, the current tends to concentrate towards the outer surface of the conductor. The higher the frequency, the thinner this conductive layer is, and the thinner the layer the higher the resistance.
For more details see:
https://www.google.com/search?q=electrical+skin+effect
https://www.google.com/search?q=inductive+heating
https://en.wikipedia.org/wiki/Induction_heating
Cheers,
Tom
abdulbadii said:
TL;DR Summary: Help solve tangled transformer freq contradiction over induction heating
Can you please post a reference for your equations? And the 2nd equation is pretty unreadable, IMO. Please learn to post equations using LaTeX (see the LaTeX Guide link below the Edit box). Thank you.
That equation is about the flux density in a given transformer, driven at different frequencies.
In reality, a transformer (the energy transfer type) is built for one frequency: to have the maximal permissible flux density at that frequency. And so (after rearrangement) that equation is what gives you the required turn count when you design for specific frequency / parameters.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
