Transformers in a circuit, interpreting the label
In summary, the conversation discusses the use of a transformer for a project and questions about its voltage and current capabilities. It is clarified that the transformer produces 18V AC rms and can handle up to 3 amps of current. The resistance of the transformer is also addressed and it is noted that it is not usually specified on the nameplate. The conversation also touches on the role of marketing in transformer specifications and the importance of customizing them for specific applications.
latot
24
TL;DR Summary
How can we apply a real transformer to a circuit, using a transformer with a current and voltage dc output, and how interpret the data in the label
Hi hi, I was trying to use a transformer, that typical transformer that we have in house for a project, but then I notice something, well all this can be just a misunderstand from me.
Actually a transformer have a voltage and a current, at least that is what it says the labels, "18V and 3A" for example, my first question here is, the transformer works as a voltage and current power source? (both at the same time)
Actually, from the theory, the voltage is constant, because is a proportion from the number of coil loops, and how in the input there is 220V (here in my house), I suppose the output will be in that proportion, the current have a proportion but is not necessary constant, or at least I suppose, so maybe, the "3A" just says the max current we can get from the transformer.
There is other interpretation, maybe just say, "I have 18V and 3A", says to us, "I have 18V and 6Ohms", so the 3A is just the current we get when is connected to a tester, if is this case, I have the question of how to know the max current that the transformer supports.
Thx.
latot said:
"18V and 3A"
Says it will produce 18 VAC rms. The load can draw up to 3 amps of average current from the 18 V secondary.
:O Ty, so, a transformer don't come with resistance? or just too low?
That's usually listed separately on the nameplace. Either a max current or a max VA.
latot said:
... a transformer don't come with resistance? or just too low?
The only important transformer resistance is the resistance of the wire in the windings.
The voltage, when unloaded, is designed to be about 5% higher than specified. As current increases, the voltage falls due to the winding resistance. At the maximum current specified, it meets the output voltage specification.
An 18V, 3A transformer will have about (18 V * 0.05 ) / 3 amp = 0.3 ohms of secondary winding resistance.
It isn't unusual, for off-the-shelf transformers for several parameters that you may care about to not be specified. The manufacturer's application engineers may provide a more detailed specification drawing, although this seems to be going away with cheap suppliers dominating the market.
It is common for EEs to just get a sample and characterize it themselves. This is one reason it is common for big manufacturers to make their own specification drawings and order custom or semi-custom parts. They are often the same parts, but specified differently.
The short descriptions you see on the part or when you order them are really just marketing guides so you know the intended target application. As a rough guide those numbers mean that if you put a standard voltage on the primary (not what's in your house, what the manufacturer specified), and your load on the secondary draws 3Arms, the secondary voltage will be 18Vrms. This represents the maximum load current that meets their environmental/safety/ reliability conditions.
Thx!, this was very very helpful, now I think I can use the transformers here, and test them when I need.
Likes DaveE and berkeman
The reason you seldom see complex data sheets for magnetics is that they are often customized for large manufacturers. They are most often specified, either by customers of the manufacturers, with what amounts to a BOM and a set of assembly instructions. i.e. Use this wire gauge, with this insulation; wind it as shown in drawings on this bobbin; assemble with this core this way, etc. Then the performance desired will result. Good drawings then have a few test requirements, but these are to screen for material/assembly errors, not to help designers in their selection.
FAQ: Transformers in a circuit, interpreting the label
What are transformers and how do they work?
Transformers are electrical devices that are used to transfer electrical energy between two or more circuits. They work on the principle of electromagnetic induction, where a changing magnetic field induces a current in a nearby conductor.
What is the purpose of a transformer in a circuit?
The main purpose of a transformer in a circuit is to step up or step down the voltage of an alternating current (AC) electricity supply. This allows for efficient transmission of electricity over long distances and also allows for different voltage levels to be used in different parts of a circuit.
How do I interpret the label on a transformer?
The label on a transformer typically includes information such as the input and output voltage, current, and power ratings. It may also include the type of transformer (e.g. step-up or step-down), the frequency, and any safety certifications. It is important to carefully read and understand the label before using a transformer in a circuit.
Can a transformer be used to convert DC to AC?
No, a transformer can only be used with alternating current (AC) electricity. To convert direct current (DC) to AC, a device called an inverter is needed.
What safety precautions should be taken when working with transformers?
When working with transformers, it is important to follow safety precautions to avoid electric shock or other hazards. This includes making sure the transformer is properly grounded, using appropriate personal protective equipment, and following manufacturer instructions. It is also important to never touch the transformer while it is in operation and to keep it away from water or other liquids.
