Transforming momentum between inertial reference frames
In summary, the bug's momentum is smaller in the truck frame than in the bug frame, but the absolute magnitude of the momentum is not important.
bkraabel
A bug of inertia [itex]m_B[/itex] collides with the windshield of a Mack truck of inertia [itex]m_T \gg m_B[/itex] at an instant when the relative velocity of the two is [itex]\boldsymbol v_{BT}[/itex].
(a) Express the system momentum in the truck’s reference frame, then transform that expression
to the bug’s reference frame, and in so doing remove [itex]m_B\boldsymbol v_{BT}[/itex] from the expression. (Remember, in the bug’s reference frame, the bug is initially at rest and the truck is moving.)
(b) Now express the system momentum in the bug’s reference frame, then transform that expression to the truck’s reference frame, and in so doing remove [itex]m_T\boldsymbol v_{BT}[/itex] from the expression.
(c) Is there something wrong here? How can we change the momentum by a small amount [itex]m_Bv_{BT}[/itex] doing the transformation one way and by a large amount [itex]m_Tv_{BT}[/itex] doing the transformation the other way?
Take the bug's direction as the positive direction. System momentum in bug frame is
[itex]\boldsymbol p_{sys,B}=-m_T\boldsymbol v_{BT}[/itex]
System momentum in truck frame is
[itex]\boldsymbol p_{sys,T}=m_B\boldsymbol v_{BT}[/itex]
I can see that the magnitude of the momentum is much larger in the bug frame, but I don't get the part about removing [itex]m_B\boldsymbol v_{BT}[/itex]. It doesn't seem necessary or even possible. I understand that the absolute magnitude of the momentum in different inertial reference frames is not important. What is important is the difference between momenta in two inertial frames. This difference should be the same in the two frames.
No special rules given for momentum transformation, just the regular Galilean transformation rules for transforming velocity between different frames. But applying a Galilean transformation just gives you the equations we've already written above.
Well yes - but you asked about the process.
You can just write down the equation by inspection because, basically, you know the outcome in advance... or you can start with one and formally apply the transformation step-by-step and demonstrate you get the same thing.
However, in the bug's frame, the momentum is simply the negative of the truck's momentum, whereas in the truck's frame, the momentum is the negative of the bug's momentum plus the truck's momentum. This is because the truck's frame is moving and has its own momentum, while the bug's frame is stationary and does not have its own momentum. Therefore, the transformation of m_B\boldsymbol v_{BT} is not necessary and does not change the overall momentum of the system. In conclusion, there is nothing wrong with the calculations and the difference in magnitude of the momenta is simply due to the different reference frames.
FAQ: Transforming momentum between inertial reference frames
1. What is an inertial reference frame?
An inertial reference frame is a system of coordinates that remains at rest or moves with a constant velocity in a straight line. It is used to describe the motion of objects in a consistent and predictable manner.
2. How is momentum defined in physics?
Momentum is defined as the product of an object's mass and velocity. It is a vector quantity, meaning it has both magnitude and direction, and is conserved in a closed system.
3. What is the principle of conservation of momentum?
The principle of conservation of momentum states that the total momentum of a system remains constant, unless acted upon by an external force. This means that in an isolated system, the total momentum before and after an interaction will be the same.
4. How does momentum change between inertial reference frames?
Momentum can change between inertial reference frames due to the relative velocities of the objects in each frame. This change in momentum is described by the principle of relativity, which states that the laws of physics are the same in all inertial reference frames.
5. What are some real-world applications of transforming momentum between inertial reference frames?
Transforming momentum between inertial reference frames is essential in many fields, including space exploration, transportation, and sports. For example, understanding the transfer of momentum between rockets and their propellant allows for more efficient space travel, and understanding the momentum of moving vehicles is crucial for designing safe and efficient transportation systems.
