MHB Transforming Trigonometeric Identities II
  • Thread starter Thread starter Drain Brain
    identities
The discussion focuses on transforming a trigonometric identity involving sine and cosine functions. The left member is manipulated by regrouping and factoring, ultimately leading to a simplified expression. Key transformations include using Pythagorean identities and expressing terms in relation to tangent and cotangent. The final steps involve multiplying by a strategic factor to achieve the desired form on the right member of the equation. The transformation successfully demonstrates the equivalence of both sides of the identity.
Drain Brain
Transform the left member to the right member.
$\frac{\left(\sin^{2}(\phi)\cos^{2}(\phi)+\cos^{4}(\phi)+2\cos^{2}(\phi)+\sin^{2}(\phi)\right)}{1-\tan^{2}(\phi)}=\frac{3+\tan^{2}(\phi)}{1-\tan^{4}(\phi)}$
I begin by regrouping the numerator of the left member$\frac{\left(\left(\sin^{2}(\phi)\cos^{2}(\phi)+\cos^{4}(\phi)\right)+2\cos^{2}(\phi)+\sin^{2}(\phi)\right)}{1-\tan^{2}(\phi)}$
then factoring out $\cos^{2}(\phi)$ I get,$\frac{\left(\cos^{2}(\phi)\left(\sin^{2}(\phi)+\cos^{2}(\phi)\right)+2\cos^{2}(\phi)+\sin^{2}(\phi)\right)}{1-\tan^{2}(\phi)}$
using Pythagorean identity
$\frac{\left(\cos^{2}(\phi)(1)+2\cos^{2}(\phi)+\sin^{2}(\phi)\right)}{1-\tan^{2}(\phi)}=\frac{\left(3\cos^{2}(\phi)+\sin^{2}(\phi)\right)}{1-\tan^{2}(\phi)}$knowing that $\cot^{2}(\phi)\sin^{2}(\phi)=\cos^{2}(\phi)$ and $\tan^{2}(\phi)(\cos^{2}(\phi)=\sin^{2}(\phi)$ I will replace the terms in the numerator with these relations.
$\frac{\left(3\cot^{2}(\phi)\sin^{2}(\phi)+\tan^{2}(\phi)(\cos^{2}\right)}{1-\tan^{2}(\phi)}$
I will now express $\cot^{2}(\phi)$ in terms of tan,$\frac{\left(\frac{3}{tan^{2}(\phi)}\sin^{2}(\phi)+\tan^{2}(\phi)\cos^{2}(\phi)\right)}{1-\tan^{2}(\phi)}$
factoring out $\frac{3}{tan^{2}(\phi)}$
$\frac{\frac{1}{tan^{2}(\phi)}\left(3\sin^{2}(\phi)+\tan^{4}(\phi)\cos^{2}(\phi)\right)}{1-\tan^{2}(\phi)}$
placing $\tan^{2}(\phi)$ in the numerator and distributing into the denominator I have
$\frac{\left(3\sin^{2}(\phi)+\tan^{4}(\phi)\cos^{2}(\phi)\right)}{\tan^{2}(\phi)-\tan^{4}(\phi)}$
further manipulation of the second term in the numerator and factoring out $\sin^{2}(\phi)$ I wound up with,
$\frac{\sin^{2}(\phi)\left(3+\tan^{2}(\phi)\right)}{\tan^{2}(\phi)-\tan^{4}(\phi)}$
From here I couldn't go any further. What should I do?
Mathematics news on Phys.org
You are good up to this point:
$$\frac{\sin^2(\phi)\left(3+\tan^{2}(\phi)\right)}{\tan^{2}(\phi)-\tan^{4}(\phi)}$$
Divide numerator and denominator by $\sin^2(\phi)$ to get:
$$\frac{3+\tan^{2}(\phi)}{\sec^2(\phi)\left(1-\tan^{2}(\phi)\right)}$$
Now, apply a Pythagorean identity to $\sec^2(\phi)$, and what is the result?
Hello, Drain Brain!
Prove: $\;\dfrac{\sin^2\!x\cos^2\!x+\cos^4\!x+2\cos^2\!x+\sin^2\!x}{1-\tan^2\!x)}\:=\:\dfrac{3+\tan^2\!x}{1-\tan^4\!x}$
You did fine, up to: $\;\dfrac{3\cos^2\!x+\sin^2\!x}{1-\tan^2\!x}$
Multiply by $\frac{1+\tan^2\!x}{1+\tan^2\!x}$
$\quad\dfrac{1+\tan^2\!x}{1+\tan^2\!x}\cdot\dfrac{3\cos^2\!x + \sin^2\!x}{1-\tan^2\!x} \;=\;\dfrac{\sec^2\!x(3\cos^2\!x + \sin^2\!x)}{1-\tan^4\!x}$
$\quad =\;\dfrac{3\sec^2\!x\cos^2\!x +\sec^2\!x\sin^2\!x}{1-\tan^4\!x} \;=\; \dfrac{3 + \tan^2\!x}{1-\tan^4\!x}$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
