Transforming Vectors: Real-Life Examples Beyond Inclined Planes
In summary, transforming a vector from one basis to another is necessary in various real life situations such as changing reference frames, using different units of measurement, studying different types of motion, and working in different fields including economics, field theory, and vector spaces of continuous functions. Linear algebra is a useful tool in many areas beyond just euclidean 3-space.
matqkks
285
Why would we want to transform a vector in our normal basis (xyz axes) to another basis? The only situation I can recall is when we are looking at a force applied on an inclined plane. Are there any other real life examples where this may be necessary?
When you wish to charge reference frames. For instance you may want to change from the natural reference frame for an aircraft (x along the aircraft axis, y in the plane of the floor to the right, and z in the direction of the cabin roof) to an Earth base axis system.
CB
to expand on CaptainBlack's example, one may take physical measurements in 2 different locations. a different "origin" (reference point) may be used at each location (instead of a common reference point like the greenwich observatory).
or one may simply use different units of measurement, resulting in the need for "scaling factors" in the unit vectors.
in the world of acoustics, one may have different oscillators (or circuits) one uses for generating (or processing) sound. so different settings may be required to produce a (nearly identical) sound on differing pieces of equipment.
for studying some kinds of motion (like projectiles) a rectangular coordinate system may be the most convenient, for studying other kinds (like orbits), a polar system may work better. we need to know how to go "back and forth" between the two.
in economics we may note that different economic quantities may vary linearly (or can be approximated linearly), and be linearly independent. depending on what you want to DO with this information, you may want to consider each quantity as a "basis element" or you may want to consider "aggregates" (perhaps prices as a linear combination of various cost factors) instead as a basis (for determining a suitable price index in a certain industry, perhaps).
in field (galois) theory, it may be "natural" to consider two different bases for the same space. for example, it turns out that the field generated by a (primitive) 3rd root of unity over the rationals is the same field generated by a (primitive) 6th root of unity. if we call the 3rd root w, and the 6th root u, we have:
w = u2 or 1/u2
u = -1/w or -w
which means that either the basis {1,u} or {1,w} can be used when dealing with this field.
for more complicated vector spaces, such as the vector spaces of all continuous functions defined on a real interval [a,b], there may be no natural "standard" basis. so depending on which functions in this vector space you are studying (exponentials, polynomials, etc.) certain bases may be more convenient to work with. a fact proved in one basis may indeed "transfer" to another basis, but to do so, you might need "the change of basis" transformation (usually, for large vector spaces such as this one, describing such a transformation by a matrix is not feasible).
the point i want to get across is that linear algebra applies to "much more" than just "euclidean 3-space" (the normal xyz-system you are accustomed to). it's a very useful tool for many areas (ballistics, economics, statistics, manufacturing optimization, signal processing, cryptography, it's a long list...) that we wouldn't normally conceive of as "spaces" (in the geometric sense).
FAQ: Transforming Vectors: Real-Life Examples Beyond Inclined Planes
How are vectors used in real-life examples?
Vectors are used in a variety of real-life examples, such as navigation, engineering, and physics. They are used to represent both magnitude and direction of a physical quantity, such as force or velocity.
Can you give an example of transforming vectors in everyday life?
One example of transforming vectors in everyday life is when a car is making a turn. The velocity vector of the car changes as it turns, with the magnitude and direction of the vector constantly changing.
How do you calculate the transformation of vectors in three dimensions?
To calculate the transformation of vectors in three dimensions, you can use the dot product and cross product. The dot product gives the magnitude of the projected vector in the direction of the other vector, while the cross product gives a vector that is perpendicular to both original vectors.
Can you explain how vectors are used in force diagrams?
Vectors are used in force diagrams to represent the magnitude and direction of different forces acting on an object. By summing up all the vectors, you can determine the net force and predict the motion of the object.
How are vectors used in computer graphics?
Vectors are used extensively in computer graphics to represent and manipulate objects in 2D and 3D space. They are used to create and transform shapes, as well as determine the position and orientation of objects in a virtual environment.
