Transient in a coupled circuit
In summary, Kirchhoff's laws and Laplace Transform were used to solve for the energy in an electric circuit with magnetic opposition. I found that the energy comes out to be 8 J at t=0. Additionally, the secondary current in the circuit is 2 A.
cnh1995
1,164
Kirchhoff's laws
Applying KVL on primary,
di1/dt+i1=5+2di2/dt...1)
Similarly for secondary,
2di1/dt= 4di2/dt + i2...2)
After solving these equations using Laplace Transform, I got
I1= 5-e-0.2t A and
I2 = 2e-0.2t-2e-0.25t.
I have verified these answers using initial and final conditions and I believe they are correct.
However, at t=0, the energy in the system comes out to be 8J (E= 0.5L1i12+0.5L2I22-Mi1i2, since there is magnetic opposition).
How is this possible? How can the energy change instantaneously here?
For E to be zero at t=0, i2 at t=0 should be 2A. But here, i2|t=0= 0A.
What am I missing here?
I1 (0) looks to be 4A per your solution to I1, which does not seem right. I1(0) and I2(0) both need to be zero, yes?
I1= 5-e-0.2t A and
Your I1 looks good, but I2 is suspicious. How does a second time constant arise?
Blame it on the mutual inductance. Since ##\frac{dI}{dt}## will be nonzero at ##t = 0## for both loops, there will be induced currents regardless of the "rule of thumb" behavior that we assume for isolated inductors.
Likes cnh1995
I will check the math again. But I2 should be zero at t=0 and at t=∞. I believe a single time constant can't make that happen.
Also, in the KVL equation, while taking LT of di1/dt, I wrote sI1(s)-i1(0) and put i1(0)=0. How come it is not that same in the final expression for i1?
Also, in the KVL equation, while taking LT of di1/dt, I wrote sI1(s)-i1(0) and put i1(0)=0. How come it is not same in the final expression of i1?
Plus, di/dt at t=0 in a normal series R-L circuit is E/L (non-zero). I didn't understand your point about di/dt being non-zero here.
The fact that the currents will be changing means that there will be changing flux though the loops each caused by the changing current in the other loop. Then, regardless of the usual "I = 0 at t = 0 for an inductor", Faraday's law says that a changing flux in a loop will induce an EMF.
When I do these sorts of problems I usually re-draw the circuit and write in the Laplace Domain values for the circuit components. Then write the equations by inspection. So for your circuit,
hence:
By the way, I've confirmed the results of the above analysis using LTSpice to simulate the circuit:
As you can see, ##i_1## does indeed start off at 4 amps, and ##i_2## at 2 amps. Goes against intuition, but the math bears it out.
Likes cnh1995 and Grinkle
I also ran a simulation on my phone and it is giving me the same result.:smile:
Well, I believe I2 must start off at 2A as per the energy equation in the OP.
I am getting the exact same equations in the s-domain as you are, but my answer for i2 has two time constants.
Also,
Why is this happening?
gneill said:
As you can see, i1i1i_1 does indeed start off at 4 amps, and i2i2i_2 at 2 amps. Goes against intuition, but the math bears it out.
On the secondary side, as per the KVL equations, mutually induced emf is the "source" and L2 and R2 behave as the load.
At t=0, this mutually induced emf Mdi1/dt equals 0.4V.
How come the secondary current is 2A? That would require at least 2V in the secondary.
This circuit is crazy!
Let me cheat and use Mathcad to do all the work:
Again, Faraday's law says that the induced EMF will be spread out all along the loop. While we model mutual inductance as a simple source in series with the inductor, it's really not. The current induced by the EMF is not truly the ##I_1## of the diagram.
Edit:
What I meant to say is, the 5 V source is not the only source of EMF driving current ##I_1##. And the induction based contribution is driven by Faraday.
Likes cnh1995
Yes, when you solve both the s-domain equations simultaneously, you get i2=2A and that doesn't violate the physics of circuits!:smile:
Perhaps my thinking below is incorrect because the Laplace equations have something to do with discontinuity of the current function at t=0.
I found the expression for i1(t), then found the expression for Mdi1/dt and then took the LT of the equation
Mdi1/dt= i2+4di2/dt.
If you solve this, you get
Why is this method incorrect?
I'm not sure, but perhaps because you lose the fact that there is an initial "DC" current of 5 amps when you differentiate in the time domain? If I do the differentiation in the Laplace domain (simply by multiplying ##I_1(s)## by ##s##), then I have
##2 \frac{5 (4 s + 1)}{(5 s + 1)} = I_2(s) + 4 s I_2(s)##
and
##I_2(s) = \frac{10}{5 s + 1} ##
Likes cnh1995
and
I agree, that must be it!:smile:
I had removed the 5A dc simply by taking its derivative in the time domain.
Thanks for all your help!
Likes gneill
It may be noted that it's fortunate that the coefficient of coupling is unity.
If for example M=1 instead of 2 we would get I1(s) = (4s+1)/[s(3s2+5s+1)] with pretty tortuous inversion math. Ditto for I2.
Likes cnh1995
Related to Transient in a coupled circuit
1. What is a transient in a coupled circuit?
A transient in a coupled circuit refers to a temporary change in the voltage or current in a circuit that is caused by a sudden change in the input signal. This change can occur due to a variety of factors such as switching on or off a power source, sudden changes in resistance or capacitance, or the introduction of a new signal.
2. How does a coupled circuit produce a transient?
A coupled circuit produces a transient when there is a change in the electromagnetic energy stored in the circuit. This can occur when there is a change in the magnetic field between two or more coupled inductors, which induces a voltage in the circuit. This voltage can cause a temporary change in the current flow, resulting in a transient.
3. What is the significance of a transient in a coupled circuit?
Transients in coupled circuits can have a significant impact on the performance and stability of the circuit. They can cause unwanted voltage spikes and oscillations, which can damage components and disrupt the normal operation of the circuit. It is important to understand and control transients in order to maintain the proper functioning of the circuit.
4. How can transients be mitigated in a coupled circuit?
There are several techniques that can be used to mitigate transients in a coupled circuit. These include using snubber circuits, adding diodes or capacitors, and using proper grounding techniques. It is also important to consider the design and layout of the circuit to minimize the effects of transients.
5. Are there any real-world applications of transients in coupled circuits?
Yes, transients in coupled circuits are a common occurrence in many electronic devices and systems. They can be seen in power supplies, motor control circuits, and radio frequency systems, among others. Understanding and managing transients is essential in the design and operation of these systems to ensure reliable and safe functioning.
